![]() | Home > Technical (L322) > Faint flickering airbag light |
| Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234
I have noticed tonight in the dark that the dashboard airbag light is ever so faintly flickering.
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Sounds like a dodgey earth - do you leave the AC on all the time? |
Generally I don't have the AC on in this weather CURRENT : FFRR 2012 4.4 TDV8
Then the moisture in the air gets into the various connections/ecu's in the car and will generally give you various errors all over the place.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
It seems many people do not realise that Climate Control is not Air Cooling!
If you're going to rubbish my comments - please objectively explain why?
| Patricktet Member Since: 04 Aug 2013 Location: Norway Posts: 7
I have the same flickering airbag light, did you find out what it was? MY 06 Vogue TD6 Buckingham Blue |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
the occupancy sensor might be faulty..does the light flicker when you move about in the seat.. ... - .- -.
Do you always use the AUTO A/C setting.... |
AC is always on, and the car is in a garage overnight. I have been out jumping up and down it the seats without any difference, still flickering |
try doing that in the passenger seat and see if that makes a difference.. ... - .- -.
did that already |
also check the connections under the seat , one might be loose or even the pins might be corroded.. ... - .- -.
