| Suspension failure and HDC warning | |
Just fitted new discs and pads all round on my TD6 Vogue - the rears were a real pain to remove due to corrosion jamming against the hand brake shoes ! After everything was fitted I checked the fluid level in the brake resevoir and it was leaking over the top of the filler cap (I had removed the top before hand and wrapped a towel around in case this happened). Anyway - to soak up and remove the excess fluid i had to unclip the electrical connection on the cap - did this and removed said excess fluid to the correct mark with the cap refitted.Connected the electrical plug back up and tokk the car for a test drive to ensure the brakes etc were ok. Imediately had the check brake fluid warning light lit along with suspension failed and locked in normal height and the dreaded HDC failure warning displayed, Tried turning engine off and on again with no effect. Upon rechecking the electrical connector on the brake fluid reservoir all was ok , along with the fluid level , so I unplugged the connector and plugged it back in again and all warnings cleared, It would seem there is a lot 'tied in' with the brake fluid reservoir so maybe worh a look at when drivers experience the other two faults I had !
