Home > Maintenance & Mods (L322) > does oil suction work on TDV8
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
considering buying a suction device such as Pela / Sealey etc. great reports on other forums on other cars but cant find any views on here. some engines apparently are not suited as there are engine bits in the way when you stick the suction tube in the dipstick hole.
anyone used on TDV8?
Post #212368 26th Sep 2013 12:21am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
dont know about the diesel...but used one on mine once,,,no problem
cant see what would be in the way of the "dipstick"..... the end of the pela is only a dipstick with a pipe on it in reality free use of "RSW" all comms to anyone nearby
Post #212374 26th Sep 2013 7:36am
You would need to measure what comes out to determine whether you manage a full sump drain or not. Some engines are not suitable for this method of draining, I know certain VW Passats caannot be done with vacuum pumps as it leaves a substantial amount of oil still in the sump
Post #212376 26th Sep 2013 7:52am
I can't see how this would get rid of the gunky stuff at the bottom of the sump that normal draining would flush away. I would have thought draining from the lowest point would always be preferable. Previously..
Post #212384 26th Sep 2013 8:31am
dexion7
has anyone actually used one on TDV8?
the wiki suggests that using the drain plug will cause a tsunami of oil. i suppose if even 90% was removed using a suction device it would make the drain plug removal afterwards an easier operation.
Post #212388 26th Sep 2013 8:47am
I often use a vacuum pump for draining oil and if you get the suction pipe correctly placed you can extract over 99% of the oil
Post #212394 26th Sep 2013 9:18am
dexion7
which model would you recommend for TDV8?
is there a restriction on the tube diameter that can fit down the dipstick pipe?
it seems that a bigger diameter tube would be better
Post #212405 26th Sep 2013 10:15am
cass
I use one on my TDV8 - The 1st time I used it I took the sump plug out to see how much oil was left in.
There was less than half a litre
Post #212432 26th Sep 2013 12:09pm
dexion7
which device did you use?
Post #212433 26th Sep 2013 12:10pm
FYI doesnt the RR and other LR products have baffles in the sump that could cause issue with this?
IMO the oil service hatch is easy to take off and having one of those 99p buckets from B&Q to drain into gives plenty of surface coverage for when the oil comes out.
Just have the bucket set so its as close the opening as possible with more of the buckets catch area to the rear so it gets it as it shoots out but leaves enough for when the flow calms down if you get what i mean.
Or pay nationaltyres or the like the tiny amount of money they ask for to do it and watch them like a hawk Smile
And if they want to charge for sump cover just take it off before you head over as its a 2 minute job if that Smile
and apply some grease on the threads to make it easier next time you need it off as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #212436 26th Sep 2013 12:24pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Don't know about the TDV8, but earlier today I used a Sealey 6.5L vacuum pump on my TD6 and removed just under 8 litres of oil out of the engine. The oil I removed was a cheaper 5w40 synthetic I had previously put in to flush the engine prior to draining the rest via the sump plug, replacing the filter and putting in Castrol Edge.
A vacuum pump is really useful for a quick oil change between the normal oil and filter service interval. I've used the Pela one's before; the Sealey is far better but more expensive. I also use the Sealey on my wife's car for 'intermediate' oil changes.
Post #212449 26th Sep 2013 3:32pm
dexion7
how long does the sealey unit take to remove that much oil - did you warm the engine first?
Post #212450 26th Sep 2013 3:34pm
cass
Mines a Sealey unit, it is a slow process I've never timed it - I just make sure that the engine is hot, set it away 1st and by the time that I've changed the oil and air filters it's ready to fill back up again.
I bought mine a few years ago for a different job after seeing one being used in a franchised Jag workshop. It works well on almost every car I've tried it on except a BMW530D and a Citroen something I can't remember.
Can't fault mine, it's way more convenient than rolling about underneath and as I change the oil and filters every 10K I don't believe that any old oil left in the sump is going to cause a problem.
Post #212459 26th Sep 2013 4:24pm
Vogue
Might work on a 3.6, but definitely won't on a 4.4 TDV8 as it doesn't have a dip-stick.
Wouldn't use one on any of my vehicles due to the reasons mentioned above 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #212470 26th Sep 2013 4:56pm
J90
A Sealey vacuum pump is still a great tool to use when you need to change just your oil between normal oil and filter service.
It's a great tool to remove the majority of your oil before removing the sump plug and draining the rest of the crap out for a full filter and oil change.
I'm a fan of the vacuum pump; obviously for garage use. Smile
Post #212478 26th Sep 2013 5:51pm
