![]() | Home > General > Head light adjusting - driving on the continent |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
I can't tell from your profile what your car is - but on mine you just move the lever inside each headlamp up or down to change from RHD to LHD. |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 ![]() ![]() ![]() |
Thanks, will take a look.
Is that a little white lever, inside the cover? |
Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 104 ![]() ![]() ![]() |
I would be interested to know the outcome of this (we have a trip across Spain coming up). I have had the cover off the back of the lights (twist and unlock) and can also see the little white lever. |
The manual is useless in this respect - if it explains it in there I can't find it, not in the least bit obvious. |
Right, sorted this |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 263 ![]() ![]() |
What he says. You feel a slight resistance to pressure in the "correct" direction. Point your car at a wall/garage door and look at the light pattern. If the top of the pattern is flat, you have continental settings. If it has a peak to the left, you have UK settings. 2021 3.0 P400 Vogue
