Home > General > Head light adjusting - driving on the continent
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Chaps,
Going on hols in France shortly and will be taking the RR - how are the lights adjusted to dip the other way?
Thanks
Post #21201 28th Jun 2010 9:26am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I can't tell from your profile what your car is - but on mine you just move the lever inside each headlamp up or down to change from RHD to LHD.
Post #21221 28th Jun 2010 1:14pm
Duke Thrust
Thanks, will take a look.
(4.4 Vogue - BMW engine)
Post #21222 28th Jun 2010 1:43pm
Duke Thrust
Is that a little white lever, inside the cover?
Post #21260 29th Jun 2010 10:19am
Kilovolt
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
I would be interested to know the outcome of this (we have a trip across Spain coming up). I have had the cover off the back of the lights (twist and unlock) and can also see the little white lever. Cool
Not sure what to do with the lever save snap it off in ignorance (so I left it alone). Crying or Very sad
Any guidance welcome. Sheep Currently running FFRR MY10 TDV8 3.6L and a Disco 3 XS Commercial (tank like but very effective as a Company van). Plus one mint condition Track Day Car in the form of an E36 M3 3.2L Evolution circa June 1996 with lots of go faster bits and only 52k miles on the clock! Oh, plus a few bits to make it slow down really quickly as well! Luvverly.
Post #21263 29th Jun 2010 11:25am
Duke Thrust
The manual is useless in this respect - if it explains it in there I can't find it, not in the least bit obvious.
Post #21264 29th Jun 2010 11:29am
Duke Thrust
Right, sorted this Very Happy
It was the little white lever, it's spring-loaded so always returns to centre which makes things a touch confusing.
When pressed down you can see a little 'shield' move across the face of the bulb to alter the pattern (you have to squint into the lens as it's all magnified and looks very odd).
Post #21315 30th Jun 2010 8:30am
JW911
What he says. You feel a slight resistance to pressure in the "correct" direction. Point your car at a wall/garage door and look at the light pattern. If the top of the pattern is flat, you have continental settings. If it has a peak to the left, you have UK settings. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #21496 2nd Jul 2010 9:40pm
