![]() | Home > General > new owner looking for advice |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
ask for gas cert you need it for insurance if anything happens |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
check it has had the front dif recall replacement
Is the car home yet might pop and have a look tonight drop me a pm with tel no or post code mate |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Trim strips from main dealer only , contact Dan , get his number on speed dial ! |
Just called up to see it will be loads better once he gets it cleaned and polished up |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
As we all know cosmetics count for nothiong, they can be sorted easily, although not a nice experience for a newbie |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 ![]() ![]() |
car going in to range rover main dealers for a once over tomorrow |
Fingers crossed, as long as OK mechanically then it will be worth it, my L322 has been in hospital for 3 weeks just to get the F |
inspection completed and road test by land rover technician at stratstone dealers all happy days drive good no faults bar low break pads on rear |
Good to hear it is technically sound, looks are relatively easy to fix up. Bit of elbow grease with the detailing products and tools and a car can look a million dollars after a day of hard work.
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
Samp5679
I will post pics just as soon as I have found out were all oil is coming from on my drive and check coolant level message keeps popping up ,, not bad for 4 days ownership |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Green ovals, no mater what kind always leave there make on the drive......Its only marking its territory |
Is it saying it when you first start it up on your drive, if so might just be the angle its sitting at try and turn the car round and see if that changes anything. Or has it lost any water, if so get a pressure test on it and see if its just a hose leaking. |
