![]() | Home > Maintenance & Mods (L322) > Brembo caliper threads |
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
Thanks for this, really useful info.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
This happened to my front caliper. When i did my brakes i came to take the drivers side caliper off only to find that one of the bolts was tight as a tight thing. But the bolt did not crack off, it was tight all along the thread. I had a look when it was off an one of the threads was slightly mangled.....
| SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352
The brembo calipers are so easy to cross thread, it's obvious that foul play was the cause of the threading. When fitting my calipers I almost cross threaded them without even knowing.
I wondered about the helicoil but figured that the threads were much coarser than the standard, also wasn't sure about the availability of suitable HT bolts.
Two words for this..........................Copper Grease...... Simples |
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
Right on! I am a big fan of copper grease. However, I am advised that the bolts are supposed to be tightened dry with some locktight and so I have resisted the temptation and made up for it elsewhere. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Locktight in an alloy calliper with a steel bolt is a good way to strip the thread my friend |
That may explain the history as the stripped bolt that I removed had tell tale blue glue on it and it was the same dealer that recommended its use who had damaged the iriginal caliper.
| All times are GMT |
