Home > General > new owner looking for advice
Page 3 of 3 <123
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Welshdragon wrote:
Green ovals, no mater what kind always leave there make on the drive......Its only marking its territory Twisted Evil Laughing
When we got out first RR (1987 Classic) we were told that if a Range Rover doesn't leak oil there is a problem with it!! Rolling Eyes
Post #213346 1st Oct 2013 9:44am
samp5679
steve9bug wrote:
samp5679 wrote:
I will post pics just as soon as I have found out were all oil is coming from on my drive and check coolant level message keeps popping up ,, not bad for 4 days ownership
Is it saying it when you first start it up on your drive, if so might just be the angle its sitting at try and turn the car round and see if that changes anything.
Or has it lost any water, if so get a pressure test on it and see if its just a hose leaking.
Water is full yes does it on drive maybe slope on drive but can't see it possibly sensor , no water lost
Post #213351 1st Oct 2013 10:02am
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
If you've not got a coolant leak if may not have the correct mix of anti-freeze and water,have your local independent check it,if the car senses its a weak mix it will give a low coolant message on the dash.needs to be 50-50 mix Thumbs Up
Post #213457 1st Oct 2013 7:02pm
samp5679
I will check this , can't see any leaks plus level is good , maybe sensor failure as I have read its common fault , what is the preferred coolant anyone???
Post #213459 1st Oct 2013 7:07pm
clarkie
When i change mine i use o.a.t(organic acid technology) its usually orange in colour,as you dont know whats in yours give it a good flush through to remove the old as not all anti-freeze mixes together.
Post #213579 2nd Oct 2013 11:45am
samp5679
well 1 week and we have coolant light electric seats and steering wheel only work when they want and now radio wont come on great ! any ideas
Post #214736 6th Oct 2013 8:44pm
clarkie
Check both cubby boxes in the boot for water in the infotainment gubins and the fuse box on the other side,pull the plugs out and look for corrosion,if none get a diagnostics check done see if any codes come up.
If all clear and you still have problems a packet of swan vestas and a gallon of petrol will sort it Smile
Post #214761 6th Oct 2013 9:33pm
samp5679
swan vesta way rounds good at min , no water ingress bone dry , turned sat nav on working but with no audio
Post #214769 6th Oct 2013 9:52pm
Page 3 of 3 <123
