![]() | Home > Maintenance & Mods (L322) > tow bar is bolted and welded..!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35822 ![]() ![]() |
this is what yours should look like,
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
ALSO take into account if you take of the towbar you need some parts to get the exhaust and the bumper back up
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
And if you did take it off completely and were able to refit the rear bumper would you a) ever be able to resell it, and b) Invalidate your insurance by making the car non-standard and possibly losing vehicle crash integrity? |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
PaulTyrer
yeah that's the one,see where the tow eye is,you have like a flat plate that goes vertical,well that's welded to the metal cross member part under my rear bumper..and either side of it you have these hooks with rubber hangers that the rear exhaust box is attached too...but yeah that's the baby that's attached under my vogue...its looking more and more like i will have to just leave it there....thank you for your help ![]() |
I'm not 100% sure, but I would think that if you take off what is in effect (possibly?) a structural member from the car (if it does in fact support the rear bumper) then if you are rear-ended the insurance company may not cover you. I'd check first.
true say paultyrer..you have a very valid point there,,thank you |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Sorry to jump this thread, looking at towing with my FFRR.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
A towbar is an accessory that may or may not be fitted to a car by choice.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
When a towbar is fitted to an L322 you remove the two rear bumper brackets and replace with the tow armature which has new brackets as part of it.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8773 ![]() ![]() ![]() |
^^ As Martin says if you dont have the brackets which were removed in order to fit the tow bar then you will have an incomplete car
Sorry to correct you Martin but the brackets are exhaust brackets and an emergency towing eye, nothing to do with the fitting of the rear bumper sir ![]() |
You are indeed correct, typed in a rush |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
This may help, it's a link to the Installation Instructions on ToPIx :- http://topix.landrover.jlrext.com/topix/co...tabs=false |
