Home > Maintenance & Mods (L322) > Rust Proofing
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Rust Proofing
After being under my car looking for leaks I've noticed its looking partial to rust. Is there any treatment or DIY method I can do to slow it down?
Post #213961 3rd Oct 2013 10:43pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
waxoyl is good for the defender I guess that would work on a RR Bushy
2003 RR Vogue Monté Carlo Blue
Post #213962 3rd Oct 2013 10:46pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Clean the rust off first and coat with WURTH rust converter then waxol
Post #213968 3rd Oct 2013 10:52pm
crookedm
Next ebay search. Many thanks.
Post #213974 3rd Oct 2013 10:59pm
pld118
Bellini has recc Dinitrol for rust/ corrosion.
Here is the website link:
http://www.dinitrol.co.uk/rust_prevention_waxes_and_oils.aspx
Post #213977 3rd Oct 2013 11:08pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Tried the waxoyl and found it prone to getting washed off as its wax and oil. This year I have used Dinitrol - they use it in the MOD and on oilrigs , and being wax with no oil has a higher resistance to getting 'washed' off Thumbs Up Also contains corrosion inhibitors etc as waxoyl but does tend to cost a little more. Will see how it goes this winter and see if it was worth the extra cost Wink
Post #213998 4th Oct 2013 7:28am
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
done mine 4 weeks ago,this is where the beauty of the air suspension pays off as you set it to the highest level and get under the range on a creeper ,a tin of waxoyl a 2.5 inch paint brush and waxoyl to your heart content and white spirit to clean up after as it can get very messy...2 days later the waxoyl is dry and sets hard,winter protection done. Very Happy ..the beauty of it is, whilst under the r.r you get to inspect all the various bushes and see the state of other working components of the r.r.. Cool
Post #214328 5th Oct 2013 8:55am
I coat all the brake pipes with grease and then spray the whole of the underside of the car with a can or two of "Spray Oil" from ASDA. Do it each year, no corrosion, even living next to the sea with the inevitable salt spray. Road dust tends to stick to the oil creating a sticky,oily residue. I treat all the cars this way.
Post #214348 5th Oct 2013 9:56am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
and if you dont fancy doing the waxoyl yourself....there are workshops that will do a professional job for you....
Post #214363 5th Oct 2013 10:15am
pld118
"...2 days later the waxoyl is dry and sets... "
Does the car need to be 'parked up' for a couple of days after doing this then?
Thanks...
Post #214508 5th Oct 2013 5:56pm
greasemonkey1
as mine was done in the summer time,i didnt park the r.r. up,just carried on like normal,its only that 2 days later i checked to see how good of a job i had done that i noticed the waxoyl had dried up...i presume the natural heat helped in the drying process ...i will check the tin and get back to you to whats said on the tin in regards to drying time..cheers..
Post #214522 5th Oct 2013 7:08pm
pld118
Thanks.. Is it dinitrol you used as well?
Post #214528 5th Oct 2013 7:41pm
greasemonkey1
@ pld118 according to the instruction on the tin of waxoyl,,its reads..dries overnight and recommends a thickness of 2mm being applied for maximum protection..hope that helps,sad to say but its one of them very satisfying job for anyone who cares for their r.r to do... Thumbs Up
Post #214676 6th Oct 2013 6:22pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
I always warm it up then spray it on gets into all the corners & hard to reach places. You do end up warming it up a few times to get it all done. just sit it in a bucket of boiling water & leave for ten mins. halfords do the shultze guns to spray it with Very Happy Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #214680 6th Oct 2013 6:29pm
pld118
@greasemonkey & Mike.. Thanks v much for replies... What's product/manufacturer name and where do you buy please?
Cheers Thumbs Up
Post #214681 6th Oct 2013 6:31pm
