Home > Technical (L322) > TD6 Air filter and breather
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
I've just got a new air filter and fuel filter to change over the weekend, I was reading a post on another forum that said I'm better off changing some breather too if I'm doing the air filter?, could anyone shed any light on this? Would be handy to know what the part is called and where it's located so I can order it and replace it!!.
Post #215885 11th Oct 2013 3:51pm
Advanced Factors
Site Sponsor
http://www.advancedfactors.co.uk/llj500010...1747-p.asp
And a little snap shot off that Russian website for it's location...
 Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #215888 11th Oct 2013 3:57pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
When you get the air filter housing removed, the crank case breather filter is located at the back of the rocker cover on the drivers side of the engine (assuming right hand drive car). I found it made the job easier if you unbolt the injector wiring harness and unplug it from the rear most 4 injectors. This gives clearance and visibility to get at the Allen headed bolts holding the filter housing on. It's pretty easy to change, putting the air filter housing back on however, is a bit fiddly in my experience. Patience and getting the back two bolts started first is the key to success Thumbs Up Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #215917 11th Oct 2013 5:12pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Replace Crank breather with part # 11127799367 ( oil separator). Wont need changing again
Also please update your car thingy under your name
Gary
Post #218904 26th Oct 2013 4:17pm
