![]() | Home > Technical (L322) > TD6 Air filter and breather |
| Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198
http://www.advancedfactors.co.uk/llj500010...1747-p.asp
| B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191
When you get the air filter housing removed, the crank case breather filter is located at the back of the rocker cover on the drivers side of the engine (assuming right hand drive car). I found it made the job easier if you unbolt the injector wiring harness and unplug it from the rear most 4 injectors. This gives clearance and visibility to get at the Allen headed bolts holding the filter housing on. It's pretty easy to change, putting the air filter housing back on however, is a bit fiddly in my experience. Patience and getting the back two bolts started first is the key to success |
| 33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381
Replace Crank breather with part # 11127799367 ( oil separator). Wont need changing again
| All times are GMT |
