![]() | Home > General > looking at a high miler TDV8 |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
How high a mileage?
Alan, id'e question your indie's response my friend... Once the damage has been done "there aint no fixing it" replace it with a very big bill! Or service/flush it and prolong its life! No brainer!!!
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
Would definitely agree with what Craig says.
I don't think you're comparing like for like. The gearbox is "supposed" to be sealed for life, whereas the engine isn't......
It's the right thing to do. |
Sorry forgot to mention, not sure about the flush though, as there are different degrees of flush. |
| barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 |
car I'm looking at has done 125k miles.
Barrieeld, this link is always a good starting point to read/print out before viewing.
Sealed for life... Just like the 5 speed was in the TD6 Your choice Alan... Advise given |
I didn't say I wasn't listening Craig! Just thought that comparison between the engine oil change and gear box oil change was a bit spurious! |
Perhaps not the best choice for comparison agreed. But my point was that just because its not broke doesn't mean it wont break. And just because LR states the gearbox is sealed for life doesn't mean an oil change will not benefit the gearbox as after 70k miles or so I am pretty sure the gearbox oil is not as effective at protection as it was when new. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Tdv8 gearbox is not sealed for life and im pretty sure land rover now recommend an oil and filter change at 100k or 10 years.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
In the last month, I went for a test drive in our SC with a Master Technician from Stratstone Bury.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
did the gearbox perform better after the oil change? ... - .- -.
| All times are GMT |
