![]() | Home > Maintenance & Mods (L322) > Td6 small oil cooler gasket. |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Have you cleaned the area around the leak and confirmed this is where the leak is seeping from? |
| steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356
looks to be from that area but will get the de greaser on and clean it off and try and pin point the leak |
Mine was leaking in that area, turned out to be a loose fuel pipe |
| Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299
Having just had mine changed after a total failure I have these 2 pics of it unboxed and clean |
| greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157
hi steve you sure you're not talking about the diesel cooler,has a big black plastic air inlet going onto it...it sits on the right hand side of the engine near the top mount near the diesel filter...if you can get some pics up.. |
No mat same as cooler pic that's been cleaned |
