Home > Maintenance & Mods (L322) > Td6 small oil cooler gasket. |
Have you cleaned the area around the leak and confirmed this is where the leak is seeping from? |
15th Oct 2013 3:38pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
looks to be from that area but will get the de greaser on and clean it off and try and pin point the leak |
15th Oct 2013 4:49pm |
Mine was leaking in that area, turned out to be a loose fuel pipe |
15th Oct 2013 5:59pm |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Having just had mine changed after a total failure I have these 2 pics of it unboxed and clean
15th Oct 2013 9:49pm |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 |
hi steve you sure you're not talking about the diesel cooler,has a big black plastic air inlet going onto it...it sits on the right hand side of the engine near the top mount near the diesel filter...if you can get some pics up.. |
16th Oct 2013 7:10am |
No mat same as cooler pic that's been cleaned |
16th Oct 2013 7:58am |
