Home > Technical (L322) > Can't open the car
Page 2 of 4 <1234>
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Try the passenger door...
Post #216669 15th Oct 2013 6:03pm
Fr_Raf wrote:
Cam-Tech-Craig wrote:
The lock has an extension part on the rear, not a cable...,more like a screwdriver extension turning a screw attachment in the latch left & right working the locks...
I'm not sure to understand all the idea, but what i understand is that with a screwdriver,
- i can remove a screw ?
- or I have to move the screwdriver betwen the upper and lower level of the tailgate to make something release the lock ?
I mean the attachment on the rear of your door lock
Post #216670 15th Oct 2013 6:03pm
No key in the passenger door Sad
Post #216671 15th Oct 2013 6:04pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Simes wrote:
If I remember correctly there is also a keyhole on the passenger door - covered by a blanking plate - I think you could prise that off and try to get in that way - chance of both cables being broken is very slim!
If you remember correctly, it could realy be the better solution... I'll pray someone can confirm you're right Smile
Post #216672 15th Oct 2013 6:05pm
Fr_Raf
Bad luck... Confused
Post #216674 15th Oct 2013 6:07pm
Fr_Raf
But I can't materialize where do I have to introduce the screwdriver ?
Post #216678 15th Oct 2013 6:09pm
Ok, no scredriver... I was simply trying to explain the rear of your door lock turns in the latch assembly through an extension piece shaped much like a screwdriver... These have a habit of falling out...
Post #216680 15th Oct 2013 6:13pm
I guess he needs to know if Window Smash is his ONLY option Craig?
Post #216683 15th Oct 2013 6:17pm
I think smashing the window is better than bending the door frame to get to the door switch. Got - 2017 SDV8 Autobiography in Loire Blue
Post #216684 15th Oct 2013 6:18pm
RAC/AA or land Rover assist would be the answer in the UK Gary as they can open the boot (if your in the know) but it may be the window is the only answer in France...
Post #216686 15th Oct 2013 6:22pm
Fr_Raf
the problem is that with the screwdriver or something like, the door would not remain totally waterproof ?
Post #216687 15th Oct 2013 6:23pm
You'd more likely damage the paintwork, warping the door and/or damaging the door seal, which might end up costing more than smashing the window IMO Got - 2017 SDV8 Autobiography in Loire Blue
Post #216689 15th Oct 2013 6:25pm
Simes
Are you sure Craig? I am sure someone on this very forum (Joker?) prised the cover off the door handle and found that there was a keyhole there - and that it was just covered up?
I may have dreamed it though...
Post #216690 15th Oct 2013 6:25pm
Even though the key fob is not synchronized with the car is there any possibility the fob can be used to drive down the windows by holding down the un-lock button for 5-6 seconds? I don't hold out much hope but it must be worth a try.
Post #216691 15th Oct 2013 6:25pm
I would be surprised if that would work, as it would be a major security flaw if anybody with a random RR fob could do it........ Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #216693 15th Oct 2013 6:27pm
Page 2 of 4 <1234>
