Home > Technical (L322) > Can't open the car
Page 3 of 4 <1234>
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
I'm affraid smashing the window is the only solution I have... I'll choose the small one on rear door, my arm would be long enough to open the rear door from interior of the car. Confused
The problem is that it is not so easy to smash his own car in downtown Paris because first it is my car, and because someone would call the Police
Post #216695 15th Oct 2013 6:28pm
Why not call the police and tell then what you're going to do? Got - 2017 SDV8 Autobiography in Loire Blue
Post #216696 15th Oct 2013 6:30pm
Fr_Raf
nicedayforit wrote:
Even though the key fob is not synchronized with the car is there any possibility the fob can be used to drive down the windows by holding down the un-lock button for 5-6 seconds? I don't hold out much hope but it must be worth a try.
I tried too... with no success Sad
Post #216697 15th Oct 2013 6:30pm
Fr_Raf
You're right, but I'm affraid they tell me to call a locksmith instead of smashing my car in a public area Confused
Post #216699 15th Oct 2013 6:31pm
Fr_Raf
Simes wrote:
Cam-Tech-Craig wrote:
Simes wrote:
Try the passenger door...
No key in the passenger door Sad
Are you sure Craig? I am sure someone on this very forum (Joker?) prised the cover off the door handle and found that there was a keyhole there - and that it was just covered up?
I may have dreamed it though...
Isn't it the aftermarket cover he had on the driver door he had ?
Post #216706 15th Oct 2013 6:48pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Honestly can't remember - just seem to remember some discussions that both doors have locks on them, but the passenger one is covered (so that the same doors and handles can be used for left hand drive and right hand drive vehicles).
Post #216710 15th Oct 2013 6:58pm
A locksmith may be a cheaper option....... There is nothing that can't be fixed with a hammer😜😜
Post #216716 15th Oct 2013 7:16pm
2010 onwards UK cars have them on the passenger side with a cover (like the sport/disco 3) the earlier FF's have them on the UK drivers door Thumbs Up
That's where you have seen/read this Thumbs Up
Post #216727 15th Oct 2013 7:45pm
Fr_Raf
Then, there is no chance i'd find a key hole on the passenger door if I remove the cover ?
It seems that the problem is more important, I smashed the little window on the rear door to try opening the door with the interior handle, and nothing happen, it can't open the car, and I cant remember if the reason is that the children security is enabled or if it is not possible to open rear door when the car is lock.
I tried to push on the dashboard button, but nothing happen too... battery seems in correct condition as the warning bulbs switch on when I push on the warning button
Post #216757 15th Oct 2013 9:03pm
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
I recall if this is the BMW key types then the doors are super locked on the key or the fob which disables the interior door handles and the dash button. If yours is a 2004 I thought there was a release in the upper rear tailgate but you would need to carefully wedge the tailgate to create a small gap to get to it and maybe pull the weatherstrip away slightly and use a hooked wire or suchlike. Someone may be able to post a link to a 2004 handbook as yours is in the car...?
Maybe less damaging to get in as once in you can use the key in the ignition and then the dash button should work with the car running. Only other alternative I could think of is to have the lock barrel removed and go Craig's route of manually turning the lock with a screwdriver but then you will need new locks for door and ignition I guess.
Post #216761 15th Oct 2013 9:29pm
Simes
Aha - I knew I'd seen something about it! Cheers.
Post #216766 15th Oct 2013 9:40pm
^^^ +1
If the car has been locked using the keyfob, none of the internal door handles, pop up buttons, door un-lock switch or the tailgate release button will operate to unlock the doors... just tried all the above options.
The emergency release for the tailgate cannot, to my knowledge, be operated from outside the car..... the release is on the wrong side of a piece of metal which makes it inaccessible.
Not very helpful I'm afraid. Big Cry
I do know you can get in these cars in this locked situation but to date I haven't quite fully worked it out.
You could try contacting kp on this forum by pm, I have a suspicion he might know.
Alternatively, somehow you have to get the key in the ignition and turn the ignition on.
Post #216767 15th Oct 2013 9:43pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
I wonder if landrover power up an impact sensor which automatically unlocks the doors in an accident? Would not want to try it without some good wiring diagrams as would be very expensive if it fired all the airbags. I know ford had a problem with some of their cars being stolen by smacking the bonnet in the right place with a tennis ball & activating the sensor. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216773 15th Oct 2013 10:17pm
Fr_Raf
Well, to summarize:
- The car is super locked then I can't open it using the interior handles or dashboard button. Crying or Very sad
- I can't open the car with the key because the mechanism seems to be broken, Crying or Very sad Crying or Very sad
- I can't use remote keyfob because the key is not synchronized anymore Crying or Very sad
- I smashed the rear little window thinking that it would be enough to open the car but no. Crying or Very sad
The solution seems to start the car to release the super-lock then i have to enter the car, and it is not possible by the little window, meaning that the only solution or the cheaper one is to smashed the whole rear door window to enter the car, and change the two windows... Big Cry Big Cry Big Cry
Post #216777 15th Oct 2013 10:29pm
Are you sure it will start off key as superlocked, I would at least be taking some prof advice from landrover assist as no point just damaging your car for no purpose Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #216779 15th Oct 2013 10:34pm
Page 3 of 4 <1234>
