![]() | Home > Technical (L322) > Can't open the car |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Try the passenger door... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16372 ![]() ![]() ![]() |
No key in the passenger door ![]() |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 ![]() ![]() ![]() |
If you remember correctly, it could realy be the better solution... I'll pray someone can confirm you're right ![]() |
Bad luck... ![]() |
But I can't materialize where do I have to introduce the screwdriver ? |
Ok, no scredriver... I was simply trying to explain the rear of your door lock turns in the latch assembly through an extension piece shaped much like a screwdriver... These have a habit of falling out... |
I guess he needs to know if Window Smash is his ONLY option Craig? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I think smashing the window is better than bending the door frame to get to the door switch. Got - 2017 SDV8 Autobiography in Loire Blue
RAC/AA or land Rover assist would be the answer in the UK Gary as they can open the boot (if your in the know) but it may be the window is the only answer in France... |
the problem is that with the screwdriver or something like, the door would not remain totally waterproof ? |
You'd more likely damage the paintwork, warping the door and/or damaging the door seal, which might end up costing more than smashing the window IMO Got - 2017 SDV8 Autobiography in Loire Blue
Are you sure Craig? I am sure someone on this very forum (Joker?) prised the cover off the door handle and found that there was a keyhole there - and that it was just covered up? I may have dreamed it though... |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Even though the key fob is not synchronized with the car is there any possibility the fob can be used to drive down the windows by holding down the un-lock button for 5-6 seconds? I don't hold out much hope but it must be worth a try. |
I would be surprised if that would work, as it would be a major security flaw if anybody with a random RR fob could do it........ |
