![]() | Home > Technical (L322) > Is cruise control 'economical'? |
Cruise for the straights then when it comes to a hill just before going up maintain with the accelerator and knock the cruise off then let the speed drip away slowly as you go up the hill so as to keep the MPG semi decent and then knock it on once you get to the crest so it is even better when it comes to the downslope |
PS the link from the M56 to manchester airport slip round has some bumps in it. When i had the cruise set at 70 it would haul ass around the slip road even in the wet and then you could watch the dsc light and feel it kick in as it slid a little but stayed well under control so the systems can work together albeit fight each other as one tries to kill speed and the other tries to maintain it. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
I can confirm that using cruise in the wet is not advisable!
I think the days when cars ran rich to accelerate are gone. With cats they need to run stoichiometric all the time. I think the only exception are direct injection engines where they can run lean.
I tried cruise control in the snow on a BMW I had that also had traction control and stability control. I was waiting for a fight between them all but as soon as the traction control kicked in it turned the cruise off. I use cruise plenty in the wet but not in very heavy rain. Same with snow. I agree it's not for extreme conditions but the advice above is just not relevant for a modern car with stability systems. |
