Home > Maintenance & Mods (L322) > TDV8 Gearbox
barrieeld
TDV8 Gearbox
This is a debatable question but @ 120k miles should a TDV8 gearbox have its fluids changed to preserve its life? Or should it be ok? Range Rover SC 35th Anniversary 2006
Post #218640 25th Oct 2013 11:58am
Vogue
I would follow the manuf service schedule. if its sealed for life then it Depends on how long you are planning on keeping it and the mileage you do. If your planning on keeping it 5 years and doing 50k then change the oil. If its only a year or two then personally I would leave well alone as there are several horror stories following g/box oil and filter changes.
Post #218685 25th Oct 2013 2:58pm
Im pretty sure that LR now recommend a oil and filter change on the TDV8 box at 100,000 miles. I would check with them directly on that though as i cant remember where i heard it from. There is nothing that can't be fixed with a hammer😜😜
Post #218700 25th Oct 2013 4:40pm
Googsy
pillow talk Whistle I think you could be right as I too remember seeing that somewhere then again Confused Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #218702 25th Oct 2013 4:49pm
pld118
Master Technician at an LR UK main dealer told me that face to face a few weeks ago (gearbox 'service' should be done @ 100k miles)...
Post #218704 25th Oct 2013 5:10pm
supershuttle
I was thinking if I still have my car at 100k then I will give it a treat and change the gearbox oil. But at the current rate that will be at least 3 years from now so the car might be 10 years old --- it could be its birthday present. Anything else to plan for ? Very Happy Geoff
Post #218706 25th Oct 2013 5:57pm
We service them every 30k Thumbs Up
Post #218715 25th Oct 2013 7:07pm
ebajema
The cost of the filter and ATF is not that high. The official recommendation the dealer in the Netherlands gave me was 100,000 miles (160,000 kms). I would feel better to follow Craigs advice as the cost of a new box or a refurb job is a lot more than the cost of 3 filter/ATF changes in 100,000 miles. Just to be safe.
I have read many cases for not changing oil etc. (engine oil not ATF), I have also seen what happens to a gearbox when the ATF is not changed in time and it is all BS.
The oil is subject to thermal and mechanical loads in the engine and gearbox. Now crude oil is made into "usable" derivatives (petrol, diesel, engine oil base etc.) by cracking. Cracking is heat and mechanical load. So in actual fact your engine and gearbox are slowly breaking down the oil molecules to short molecules, changing the physical properties of the oil/ATF. So over time it changes (deteriorates) into a different type of oil. Hence the need to change it. As to when the deterioration has gone "too far" is very difficult to determine but my feeling is, stay on the safe side as the consequences of being too late can become quite costly.
To answer the OP question : I think it is high time to change no matter whether the box had an easy life or a hard life. It is past the manufacturers recommendation anyway.
Note that this is my opinion and not based on extensive and solid research or anything, just based on something that approaches common sense and conjecture. MY 2010 5.0 SC Galway green and sand interior!!
Post #218753 25th Oct 2013 9:59pm
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
What's the ball park figure my local indie says they don't do it, as might make it worse and they don't have the equipment.
I watched wheeler dealers when they fixed a boxster auto gear box by changing the filter and new ATF oil, sump off etc..
Post #219422 28th Oct 2013 11:45pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Given the probs I have had with mine I am considering it as a preventative measure but am worried over the tales of accelerating failure Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219426 29th Oct 2013 12:15am
Ball park figure should be between £250 & £500 depending on the indie...
We have repaired several Land Rover products in the same way Wheeler Dealers did the Porsche... It really does work... Thumbs Up
Post #219427 29th Oct 2013 12:18am
So what would you advise with mine at 80k now & 6yrs old ? Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219428 29th Oct 2013 12:20am
wealy
What's the worry with this? What could possibly go wrong with changing the oil and filter?
Post #219448 29th Oct 2013 8:36am
