Home > My Range Rover > 2006MY SC - Spec
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
2006MY SC - Spec
Vehicle built August 2005
Date of reg September 2005
I've done many searches and looked in the Wiki but I'm none the wiser! MY SC is badged Autobiography (but I strongly suspect someone has done that!), DVLA and HPI just say it's a V8 SC, some online look ups say it's a 35th anniversary (which it can't be as it's not red!)
Dan from Duckworth's (top man, thank you Dan!) has very kindly sent me the build sheet which has both Supercharged and Autobiography under Minor Features but am I right in saying that the ONLY thing it could be at this age is a Vogue SE?
http://www.fullfatrr.com/wiki/Trim_Levels
If anyone with better knowledge than me could take a look at the build sheet (I can send by PM) I will be very grateful. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #219393 28th Oct 2013 9:10pm
ebajema
The VIN should allow a dealer to give you the exact build sheet or did Dan already try that ? MY 2010 5.0 SC Galway green and sand interior!!
Post #219398 28th Oct 2013 9:28pm
SKOT
Yes, Dan did that and it's given me pages of extras but nowhere does it actually make reference to Vogue SE...... 2006 4.2 SC
Post #219400 28th Oct 2013 9:34pm
ebajema
Annoying. MY 2010 5.0 SC Galway green and sand interior!!
Post #219401 28th Oct 2013 9:44pm
if it helps ,this is what i have on my AB build sheet so you can compare.
Post #219402 28th Oct 2013 9:45pm
SKOT
Thanks both.
Under the 3500 kgs I also have Autobiograhy but given the age of the car (2005) there is no way it can be according to this:-
Or is it Question 2006 4.2 SC
Post #219404 28th Oct 2013 9:52pm
i suspect that the trim level entry in the wiki might not be that accurate.. ... - .- -.
Post #219406 28th Oct 2013 9:59pm
SKOT
Ah I see..............Well maybe it is an AB afterall and the AB badge on the boot is correct?
I still think it should say "Supercharged" though. Here is mine:-
But maybe the reference to "unbadged" has a meaning though...........?
 2006 4.2 SC
Post #219409 28th Oct 2013 10:16pm
as in my pm Steve i reckon the 'unbadged autobiography' bit is the answer.. ... - .- -.
Post #219412 28th Oct 2013 10:39pm
2005 mdl was just a Supercharged Vogue SE , ====================================
Post #219414 28th Oct 2013 11:08pm
SKOT
Thanks Joker - It's a 2005 registered but 2006MY. If that makes a difference? 2006 4.2 SC
Post #219418 28th Oct 2013 11:31pm
Same as the one I previously had back in 2005 ....... 2005 but a 2006 mdl Supercharged Vogue SE was the highest spec at that time as there wasn't a AB SC then , the AB SC came out in 2007 / 08 mdl ====================================
Post #219420 28th Oct 2013 11:40pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Mine was registered in 2005 as well - 2006MY Supercharged, also listed as 'unbadged autobiography' - mine has the two tone leather which I beleive is the autobiography bit.....hope this helps Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #219449 29th Oct 2013 8:47am
Vogue
Supercharged and Vogue SE have two tone leather, Extract of 06my hard back brochure above
Post #219463 29th Oct 2013 10:17am
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
check you have the autobiog plate under the bonnet at the front, should have your AB registered number
mines classed as a 2005 vogue on dvla, but is a full AB done at the LR special vehicles plant.
Post #219466 29th Oct 2013 10:20am
