![]() | Home > Group Buys > flip keys [New Order Oct 2014] |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
When you sync (any) key to the Range Rover, you have to do all the keys that you want to use - the syncing process deletes any previously synced keys.
| Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299
*Update*
It does sound like a bad cut of the key - try it in the lock the other way round (180 degrees) and see if it works then - one of mine (I had two cut) was a bit sticky in one orientation but OK in the other - a bit of jiggling it in the lock got it to work OK - but I took it back to the cutter who ran the cutter over it again (remember to take the original key that does work OK with you) and it's fine now - probably a 0.001mm of burr somewhere on the cut that is stopping it from working.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
AKIS, you have to sync all the keys you want to keep using. So it is a batch sync. If you leave one key out, it will be "unsynced" but will resync if you repeat the process with that particular key included. MY 2010 5.0 SC Galway green and sand interior!!
| AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186
Simes thanks for your clarification.Basis flip key synchronized after 30secs i have to resync the old key.Do i have to follow procedure from the very beginning,ie to turn ignition to I then to 0 and so on or just to press locking/unlocking,as stated of old key. |
| DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163
Mustard is this the old style or new style key? I spoke to daveo and had the same problem. It was because it had 2 transponder chips. I didnt know it had one in when daveo sent it to me. So just check theres only yours in there as if there is 2 it wont turn the car over |
Set the car into pairing mode (ignition on and off and key out in 5 seconds - then sync key 1 - as soon as that key is synced, don't tough the ignition or anything, and sync the next key(s) until you've done all the keys you need to use. The instructions are in more detail further up this thread somewhere. Have you got the key turning in the lock yet? |
Ebajema thanks yr reply.
Sorry +AKIS - it wasn't you who couldn't get it to turn!
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
Hi, I think most of you have got your keys working |
No just the 1 transponder but the actual key wont turn in the ignition barrel
Not yet as Ive got to get back to the key cutter and have him check the keys over, no matter what I try the key will not turn the ignition and Im out of options with it Ill be well |
mustard, do you here the click as you put the key in V8 facelift Range Rover Autobiography 22" wheels.
with no transponder no clicking,
then its down to the cutting, |
