Home > Technical (L322) > air supensioninactive prob only have jeep2weeks
Page 2 of 6 <123456>
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
have you tried disconnecting the battery and doing a full lock left and right on the steering wheel, if not you might have to get it on a diagnostic machine gone fishin'
Post #220765 4th Nov 2013 9:12pm
hse 2004
Ireland 2004 Range Rover HSE Td6 Baltic Blue
Yip had on diag computer work fine 4 2 days and then when on a overtake foot 2 floor accl.the Mess popped back on .than well try battery
Post #220766 4th Nov 2013 9:15pm
hse 2004
fuse in boot
Can any1 help me out were is the fuse4 air suspension located and what amp is it.
Post #220768 4th Nov 2013 9:24pm
Hello... No need to have 3 threads going on the same subject!! It's annoying when you want the FFRR fixed and you don't have the answer.
Have you turned the steering wheel all the way to the left, hold it a second, then all the way to the right? This resets the errors.
Have you disconnected the main battery for a while, then tried the above...
You have to do these things first..
Thumbs Up Previously..
Post #220770 4th Nov 2013 9:30pm
Fuse 57 15A on front fuseboard below glove box and fuse 18 50A on the rear fuseboard in the rear drivers side compartment for the compressor. Also worth checking the compressor relay mounted top right on the rear fuseboard. Thumbs Up
Post #220772 4th Nov 2013 9:35pm
hse 2004
Thanxwill check.fuses is the rely mount also a fuse or what D's it look like. Shocked .
Post #220779 4th Nov 2013 9:54pm
Post #220782 4th Nov 2013 10:00pm
hse 2004
Hey thanx that's really help as there is no fuse diagram on glove box fee box or back.it wold b MST appreciated if u ave these could. Send me .plzzzzzzz.
Post #220785 4th Nov 2013 10:08pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
HSE 2004: Ganz schön unhöfliche und bestimmende Art der Problemlösung, bist Du in deinem Heimatland auch so unfreundlich? Schade, aber in Italien sind die "Grandes" doch ein wenig feinfühliger, oder? So bekommt man bestimmt keine Hilfe..., aber es liegt definitiv an Deinem Kompressor, glaub mir. Viele Grüsse! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #220788 4th Nov 2013 10:09pm
@hse 2004, it would be appreciated if you could write in proper english and not 'text' speak.. Thumbs Up ... - .- -.
Post #220789 4th Nov 2013 10:10pm
Meerbusch
@ stan: top top top !!! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #220790 4th Nov 2013 10:11pm
Googsy
Even I can't understand him Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #220791 4th Nov 2013 10:11pm
Meerbusch
Kokain?? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #220792 4th Nov 2013 10:14pm
Meerbusch
Cocain?? in german: Kokain??? Rolling with laughter L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #220793 4th Nov 2013 10:15pm
Post #220794 4th Nov 2013 10:21pm
