Home > Maintenance & Mods (L322) > HOWTO: Change Thermostat on '02 TD6 FFRR
Page 3 of 4 <1234>
hidden menu's = wiki.. ... - .- -.
Post #209100 9th Sep 2013 7:50pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Thanks Stan Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #209109 9th Sep 2013 8:15pm
Got a new rad, thermal valve and coolant tank going in at the end of the month, so will see if this sorts things out! Wink .
Post #209113 9th Sep 2013 8:28pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My over cooling issue has returned again. I had a blip a few months back where it ran cooler than the usual 88 degrees. Last night driving 80 miles on the motorway it was at 67 degrees! I can't beleive I am so unlucky that the thermostat has failed again within 9 months. Could a faulty pre-heater contribute to it not reaching the correct temperature perhaps? I wondered if the coolant sensor was misreading but when I have the heating at full temperature its not as hot as it should be.
Any thoughts appreciated. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #221094 6th Nov 2013 11:02am
666tur
I swapped the thermostat today. The one removed (cheap one from euro car parts) had failed, the metal spring loaded disc that should seal the water way, was at an angle preventing a seal then snapped as I fiddled with it. I sourced a proper LR/BMW replacement from duckworths this time and after the ordeal of stripping it all down again, it is now heating to the correct temperature. That's the third time in 9months I have done that job! The lesson is don't use cheap parts on tricky jobs. 2012 4.4TDV8 VSE
Post #224823 23rd Nov 2013 7:19pm
Good job Triple 6 Thumbs Up
Since new rad, coolant tank, EGR thermal valve and removal of viscous fan (and a thermostat some time ago now) all is sweet here too .
Post #224867 24th Nov 2013 1:36am
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Hi Joe,
I have blanked my EGR off, should I worry aboot the thermos thingy?
The main thermostst?
Where is it?
I have been directed to halfvway along the right hand side of the head where the top hose seems to enter.
symptoms?
guage in 12 oclock and slightly lefy all the time.
seems to take an age to heat up.
connected a blue tooth OBD scanner with this tablet and the temp went doon to 68 and up as high as 101.
I think = thermos failing. Open to othoer thots as it seems rather a big job.
Cheers again
bill
p.s. just realised after re reading your thumbnails, my new stat does not have a space for any electric heater tho. Made in Scotland frae 'Girders'
Post #250508 25th Mar 2014 6:27pm
Here is the link to my howto for the main thermostat ( I see you found this!)
http://www.fullfatrr.com/forum/post94803.html?#94803
and for rad but also the other thermostat/EGR valve (you have to remove this to get at the main 'stat anyway
http://www.fullfatrr.com/forum/topic20909.html
Not much more to sat than dive in and enjoy Thumbs Up .
Post #250588 25th Mar 2014 10:12pm
Bofa Bill
Weil did the stat today, 3 hrs (no viscous) and only held up once by one of the torx bolts that hold the stat in place.
Such a bad design that.
Anywas, replaced and refilled.
Air bled and ran it with my tablet on OBD to get a digital readout.
Up it crept
Elec fan came on at 88 and off at 83.
Perfect.
Went for a drive and perfect.
Checked the old one and the rubber surround had perished.
A good job and pleased with the result just hope my cheap aftermarket one lasts after reading above post.
Joe, thank you for your photos and detailed intructions.
Maybe my mpg wil improve as wont be on 'choke' sometimes when it suits.
Keep yer informed as got a long trek in the morning.
Bofa Made in Scotland frae 'Girders'
Post #250792 26th Mar 2014 8:46pm
Thumbs Up Thumbs Up Thumbs Up .
Post #251018 27th Mar 2014 7:19pm
Bofa Bill
Mmmmmm 200 miles AND...........
Fixed up the tablet to the OBD.
Sorted, and away I went.
Almost imediatly I noticed that the read out was slow.
Hit the dual carragway and the temp stayed about 75 with the dash temp guage sitting at 10 o'clock.
Prior to the stat change the guage remained at 12 oclock even when OBD went up to 100.
So, sitting at 70 ( Smile ) the OBD went doon to 68 with a high of 75.
I stopped in layby and had a look under bonnet.
No pressure whatsoever on the top hose, took exp cap off with no problem. No hissing or spillage. Plenty of fluid.
Bunnet shut I carried on.
140 miles laters leave the M6 Toll amd the temp went up to 84.
Negotiating lights and round a bouts the guage crept up and back doon to 84.
Stopping at Tesco I allowed it to tick over and once temp reached 89 the elec fan came on.
All working normal noo.
It would be good if someone else could link up an OBD to compair with.
Also, any ideas as to why this is happening?
Forgot to add, when rad came oot it was rather caked up so that was cleaned.
Could the increase in cooling air flow cause this?
All comments greatly received
Bill Made in Scotland frae 'Girders'
Post #251048 27th Mar 2014 10:48pm
Sounds like the stat is stuck open. Might need a few cycles to free it otherwise it will need to be replaced. Temp guage should be rock solid at 12. .
Post #251091 28th Mar 2014 10:02am
Hey Bofa Bill
Plugged in ELM327 BT and fired up Torque Pro.
Started car from cold and let it idle to hot (while I washed it!)
At 10 o'clock (marker above the blue section) @ 52 degrees
At 11 o'clock (next marker up) @ 62 degrees
At 12 o'clock reached at 76 degrees then moved up to 89-91 degrees and steadied there, whilst remaining at 12 o'clock.
as I don't have viscous fan fitted, no electric fans came on (never have, even when sitting in traffic)
I have the standard thermostat and coolant tank lid, and understand car will run at up to 105 degrees .
Post #251562 30th Mar 2014 4:38pm
Bofa Bill
Thanx for that Joe.
Pretty much similar to mine.
I am just shocked at the temp variation while driving.
Fluctuates between 78 and 88.
Happy bunny noo.
Thanx again Made in Scotland frae 'Girders'
Post #251589 30th Mar 2014 7:01pm
Bofa Bill
Update.
200 miles mostly M/W sitting at 71Mph all the way Rolling with laughter
Temp 77 - 83 all the way.
When hit town 10mls from home temp went up to 88-93 when fan cut in, return to 80's.
All good.
Thanx again for yer help Joe.
BB Made in Scotland frae 'Girders'
Post #251817 31st Mar 2014 9:52pm
Page 3 of 4 <1234>
