![]() | Home > Maintenance & Mods (L322) > Missfire? |
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
Ok so I am hoping this is not the start of a gearbox problem.....
Thanks for that - one question - do I have to go to the dealer to get the codes read or can they be read via the OBDII and a suitable app? (app recommendations welcome)
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Does it surge when held on rake at lights etc? |
No it doesn't surge. It behaves itself in every way apart from the feeling it is running lumpy occasionally. "On first name terms with my local Dealer......now."
Right just got an app to read a code whilst the car was idling.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
http://www.obd-codes.com/p0160 ... - .- -.
Hooked up AllComms and read all stored codes - cleared them and rechecked with the engine running. Now there are no errors appearing. Will have to run the car around tomorrow and see what turns up. "On first name terms with my local Dealer......now."
| mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178
Its whats sometimes referred to as a lambda sensor. Some vehicles have them before & after the catalytic converter. The one before the cat (No1) monitors whats coming out the exhaust & sends this info to the cars ecu & alters the mixtures. The No2 sensor is after the cat & is used to monitor the condition of the catalytic converter by allowing the ecu to see the difference in the two readings. It does not affect the running of any vehicle I know of apart from possibly putting the engine management light on with a fault code alerting you to the fact the cat is knackered Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
Not had any engine management lights ever on this car. "On first name terms with my local Dealer......now."
| All times are GMT |
