Home > Maintenance & Mods (L322) > Rear track rod bolt seized advice please sorted.
Page 2 of 3 <123>
Googsy
Cheers Joe are both end required for adjustment during alignment?
Now to order parts super fast Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #221873 9th Nov 2013 5:37pm
Conor, you may miss the edit on my last post, you might actually only need the bolt nut and washers as far as i can tell that is where the adjustment is set not in the actual arm.
the bolt has an eccentric head which provides the adjustment 5K751A,RGI000012, KYF500080, RYH000061
you will need them anyway if you are cutting it out..... There is nothing that can't be fixed with a hammer😜😜
Post #221875 9th Nov 2013 5:45pm
Googsy
You are probably spot on might just replace the lot to be certain. I wonder if it's possible to un seize bolt might get some wd40 on it and get to my mechanic on monday. Hopefully Steve can sort the bits . Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221878 9th Nov 2013 5:58pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #221879 9th Nov 2013 6:01pm
Googsy
Thanks for your help guys it's not the end of the world as long as I get it done soon.
Steve you have pm with order Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221880 9th Nov 2013 6:06pm
Googsy
Out of interest has this ever happened anyone else just wondering if they are prone to wear and therefore lose ability to retain arm in correct position?
Now that I'm an expert Laughing it's no 14 that's worn on mine seems bush is worn as it just turns when bolt is turned. Thumbs Up
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221906 9th Nov 2013 9:38pm
Probably something which doesnt get looked at all too often as i would bet 90% of owners are unaware of the ability to do a 4 wheel alignment. There is nothing that can't be fixed with a hammer😜😜
Post #221909 9th Nov 2013 10:00pm
Yes I've had mine done, they need to be adjusted when you change the rose bushes
Post #221910 9th Nov 2013 10:25pm
Googsy
47 meaning the bush / bolt at chassis end does wear and causes bush to spin when tightened? thanks Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221913 9th Nov 2013 10:35pm
Could be just one of those things Googsy, seems odd that on your '08 the bush has "gone" whereas on my '02 they were still in pretty good nick when I replaced them (madly chose to replace all bushes at rear in one go!)
If bush is spinning the bolt has probably seized to it, they weren't put together with any lubricant as far as I could tell. .
Post #221932 10th Nov 2013 12:54am
Googsy
As you pointed out I'm sure they must have held one bolt whilst trying to turn the other. I think he said nut wouldn't move any further when tightening so when he let go it moved back into original spot it could be the the thread on the bolt that could be damaged. It's amazing that I have had 3 alignments recently from different garages yet they never commented that's what has me baffled .Going to my mechanic Monday as he can put it up on the ramp for a look.Thanks for your help Thumbs Up and hopefully Dan will be off the blocks with replacements. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221933 10th Nov 2013 1:07am
If the bolt is still free to turn when you tighten the nut to lock the eccentric bolt in position would it not be possible to place a washer or two under the nut so that it can then be tightened correctly?
Post #221945 10th Nov 2013 9:27am
Not sure what you're saying...
The bolt at the chassis end is an eccentric bolt, it's eccentric to allow the adjustment of the toe-in. It is either tightened or loosened, it can't wear out as it has no moving parts.
It could be rusted to the bush, but I doubt that. My suggestion would be to remove the bolt completely and fit a new bolt (that's what I did) as it makes adjusting the toe-in so much easier. I fitted all 4 new eccentric bolts when I replaced my rear bushing, the two for the toe-in adjustment and the two for the rose bushes
Post #221947 10th Nov 2013 9:41am
But if the bush actually is going round and round there is a problem .
Post #221968 10th Nov 2013 11:51am
Googsy
What does an eccentric bolt look like sorry for all the questions but trying to educate myself Embarassed Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #222102 11th Nov 2013 12:14am
Page 2 of 3 <123>
