![]() | Home > Technical (L322) > Side Step Bolt Size |
M8 and m6 I believe. I know this as I'm about to fit mine |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Easiest thing to do is to buy a fitting kit from your main agent for around £20-£30 if memory serves me correctly... There should be 8 x 10mm bolts 4 x 13mm bolts all with washers and some spacers too |
Not black are they Connor ![]() ![]() |
Nope those are stored for my Cotswold friend |
Nogin4x4 Member Since: 24 Oct 2013 Location: Hertfordshire Posts: 8 ![]() ![]() ![]() |
Have been in touch with dealer and they have quoted £54.25+vat |
you can get them in B and Q for about 9 pounds. Present :2008 TDV8 HSE
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Instructions here give some details: http://topix.landrover.jlrext.com/topix/co...tabs=false
Thanks for the link to TOPIx very useful. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
13mm bolts ?? ![]() |
I think Craig means spanner size 10mm AF -> M6, 13mm AF -> M8. |
Spanner size isn't specific to the bolt size. |
Well it normally is; there are always exceptions. |
You never tell someone what size bolt they need or order bolts by giving the size of spanner used to undo it.
