Home > Maintenance & Mods (L322) > Best place to get trans fluid?
Does anyone know of a good place to get hold of the right trans fluid for the tdv8 gearbox?
As mine does a fair amount of towing i was thinkng of getting the fluids swapped.
I know that recommended lube is a shell atf, which is the same as the ZF lifeguard 6, which woukd be in it from origiNal.
Does anyone know a good place to buy some as its quite pricey from the md and i am thinking that the zf stuff is the way to go, ive seen some on ebay and a feew motor factors down south but nothing round here.
Also anyone any idea how much i will need?
Cheers guys. There is nothing that can't be fixed with a hammer😜😜
Post #222443 12th Nov 2013 7:12pm
Can I suggest you choose wisely as there is lots of counterfeit oils around at present... Expensive mistake to make eeek... Shocked
Post #222447 12th Nov 2013 7:21pm
Martin
Site Admin
Advanced Factors do various transmission oils: http://www.advancedfactors.co.uk/transmiss...-146-c.asp
Post #222452 12th Nov 2013 7:40pm
Yes craig, thaths why im asking Thumbs Up
Was thinking whether bmw may be cheaper for the same fluid, unfortunately unlike germany we do not have a zf service facility in the uk or i would be banging on their door.
Will have a look a boringoldgit's site Martin Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #222454 12th Nov 2013 7:49pm
Zf do a kit, but looking at the pic it is the pan, pan bolts, and fluid,
Is the filter built into the pan? There is nothing that can't be fixed with a hammer😜😜
Post #222500 12th Nov 2013 9:53pm
