![]() | Home > Technical (L322) > Swan neck |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
You need to pull the handle out and turn it until it locks before pushing into the hole.Then when you push it into the reciever it will self engage.
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 980 ![]() ![]() ![]() |
cheers i will have a crack this afternoon, also i am assuming that there should be some sort of pin to keep the receiver from falling out of the armature?
A bolt with an anti vibration nut and a security pin/circlip (as it tends to constantly vibrate loose when towing weight) |
excellent, where would i purchase such an item? |
Dan |
cheers craig, will ping him a line.....
Which ones fella? |
am after the bits that go either side of the satnav screen do you have any?
I'll look tomorrow... |
cheers mate |
