Home > Technical (L322) > Suspension queries
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Suspension queries
Not sure if I dreamt this but does the suspension lower itself when at speed?
Been doing some motorway miles recently and didn't notice the RR hunkering down or the suspension lights on the dash changing.
Also every now and then when I get out (keys out, door closed) I notice the suspension lowering itself, the rear anyway.
Is this normal? Currently - 55 FFRR S/C and loving it
Post #223756 18th Nov 2013 9:25pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Once you hit 70 it drops into motorway mode!
My one sometimes drops when I'm locking it too.
Post #223758 18th Nov 2013 9:29pm
Yes it drops itself ever so slightly, so little that you wouldnt notice Thumbs Up
It may level itself slightly when parked. So long as it moves smoothly between settings it should be fine.
Dont do it too much in one go though as the air reserve tank will deplete quickly at which point the compressor will be trying to raise the car on its own and it will take ages and it will overheat. There is nothing that can't be fixed with a hammer😜😜
Post #223765 18th Nov 2013 9:53pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Kruger - the manual should point this out but as long as you have not "locked" the suspension mode (by pressing the button on the circular suspension select knob) then it will drop and raise.
I believe it is 55 or 60 mph for longer than 30 seconds and it drops to motorway mode. opposite to that is if you then drive slower than 30 for 30 seconds or so it will raise again to standard ride height.
You may find it levels itself when you park up if you are on a hill or the front/rear/left or right is higher than the other (for example left wheels on a curb. The car will always want to "level itself" and you may hear some clicks or pfffss noises when you get out for a few seconds.
You can also drop the car to access mode to make getting in/out easier if you want to. Press the upper most long button on your door (above the window and mirror switches) and the car will drop right down. It is advised to do this before you stop (under 30mph only) as apparently it like to be moving if only slightly to do so. (recommended at least). If you drop it down it will also raise again to standard when you drive away.
Have a read of your manual though as it's all in there.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #223768 18th Nov 2013 10:04pm
TugRR
. . . . I'm sure I've read it on here before that the "motorway mode" differs for different MY's ?
Mine's a '06 MY, as was my last, and neither do it . . . . either that, or I'm not going fast enough Laughing
Thumbs Up Where do you go after one of these . . . ?
Post #223771 18th Nov 2013 10:17pm
the 2002-2005/6 go down at around 65/70 mph and the 2006 onwards with the newer interior go down at 100 mph.. ... - .- -.
Post #223773 18th Nov 2013 10:26pm
kruger2002
aah... I'm not driving fast enough Wink Currently - 55 FFRR S/C and loving it
Post #223774 18th Nov 2013 10:27pm
comports
my bad - thanks Stan..!
so it's a feature one can never use in the UK.. What was the thinking behind that decision I wonder? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #223778 18th Nov 2013 10:37pm
TugRR
Laughing Me neither !
Post #223780 18th Nov 2013 10:39pm
Touchscreen cars don't have the motorway light... So, they do not lower at 65mph Thumbs Up That's the easy way to tell which is which Thumbs Up
Post #223813 19th Nov 2013 1:49am
my touch screen range did Craig...
if you have this knob then yours will lower to motorway speed around 65/70 mph.. ... - .- -.
Post #223840 19th Nov 2013 9:34am
Wrong pic Stan, it's the square box in the middle (covered in your pic by your gear stick) that looses the motorway light on the left hand side... All the rest of the panel is the same from 02-07 but the motorway light left when the touchscreen was introduced... Whistle
Post #223857 19th Nov 2013 10:21am
i did have this 'motorway' light Craig... Wink ... - .- -.
Post #223861 19th Nov 2013 10:24am
Are you 100% sure Stan Whistle Fancy a sneaky wager? Whistle Whistle Whistle
Post #223867 19th Nov 2013 10:46am
absolutely sure Craig..
the light with the number 3 [motorway height]
and here's a 2010 thread when i had my 2005 td6 and i mentioned my motorway height mode,
http://www.fullfatrr.com/forum/topic3273.h...hth+height
so, please send your cheque to ,....................................... Mr. Green ... - .- -.
Post #223868 19th Nov 2013 10:49am
