Home > Technical (L322) > Engine removal - 4.4l v8 BMW petrol
Mark_TDV8
England 2003 Range Rover Vogue 4.4 V8 Baltic Blue
Evening chaps,
A friend and I have acquired a slightly cooked l322 that seems to have suffered a water pump failure, and subsequent overheat and seizure. Our intention is to replace the engine with a takeout unit (replacing the water pump in the process) and use the car for a while.
A few of questions
Has anyone on here done this? I am not used to working on full indy vehicles where the diff is in the sump, so is there anything to watch out for during removal from the mechanical point of view?
Secondly, we need a replacement lump - does anyone have one lying around (sorry, had to ask) or can recommend a source? Have used the likes of equicar in the past, but they don't have any in stock.
Thirdly, once we have done the 'refit is the reverse of removal' thing, what nightmares are we going to have with the electrics? The car has been sat with a dead battery for roughly 6 months beforehand, so will need some sginificant ecu coaxing I would imagine...
Lastly, is there a phot walk thru or a decent manual for this car? Haynes don't appear to offer one...
I realise that's a lot to ask on a first post, but imagine I will have more questions as the project commences!
Thanks in advance
Mark
Post #223795 18th Nov 2013 11:32pm
Not sure a out the other questions but there are links to workshop manuals, generally known as rave in the wiki at the top of the page Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #223796 18th Nov 2013 11:39pm
Mark_TDV8
Good point, it never occurs to me to look at rave or microcat, but that should really be my first port of call.
Cheers
Mark
Post #223799 18th Nov 2013 11:56pm
A 4.4 engine will be expensive £3-£4K and very very hard to find as they are like hens teeth! Needs to be the same code as the engine you are removing...
Oh yeah, sorry... Welcome Thumbs Up
Post #223808 19th Nov 2013 12:55am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hopefully they are rare due to lasting forever Craig?
Mines on 155,000 miles now and every now and again I get a bit twitchy about the milage! Although it still goes like a train and doesn't burn any oil.
Post #223884 19th Nov 2013 11:24am
Rare because not many were made and most that we're had LPG Confused Fitted in there lives and ruined the engine... So hence their rarity... Thumbs Up
Post #223887 19th Nov 2013 11:28am
Simes
Fair enough - although I thought LPG on the BMW M62 unit was fairly safe?
Would the same engine from an X5 fit? Might need some ancillaries swapped - but it should be the same basic unit and there might be a few more about.
Post #223889 19th Nov 2013 11:29am
LPG do's and don'ts covered here many times before, so I won't go off topic for the OP Thumbs Up
I don't think X5 ones are the same engine code or 5 series 7 series etc etc... Hence their rarely found... Just had a customer looking and could not find one in the UK for under £4k Shocked
Post #223892 19th Nov 2013 11:35am
Simes
Fair enough on the LPG issue - I kept meaning to get mine done and never got round to it.
Depending on how badly the OP's engine seized, might be worth whipping it out and taking a look inside and seeing how bad the damage is - might get away with a rebuild - as long as the bores aren't marked as I believe you can't rebore them due to the Alusil (or Nikasil?) cylinder liners.
I've heard good things about Warrington Engine Centre - they have rebuilt a few of these - again it's not cheap - depending on what nasty things are lurking inside.
Post #223899 19th Nov 2013 11:55am
Mark_TDV8
Cheers for the welcome Wink
I am lead to believe that the specific variant is the M62TUB44, which is common to the X5 and one or two saloon cars as well as the range rover. From what I can tell the starter is in a different position on the BMW applications, but the castings are there for the RR version, so just need blanking/drilling as required for the correct position. I would have thought the Sump was specific to the RR application though, hence my initial questions above...
Having looked around, I believe I can get a running take out for less than 2k. That is the price I have been quoted, albeit by people without them in stock. Obviously that is without any ancillaries. It remains to be seen how true that is, but there's no panic so I can afford to wait.
In terms of rebuild vs replace - given the construction of the engine (alu block and head, with nikasil liners) and the price of BMW parts we decided that a complete replacement was the order of the day - obviously that won't stop us pulling the old unit apart to see exactly what state it is in!
Smile
Mark
Post #223920 19th Nov 2013 1:50pm
steptoe
It is.
Take no notice of posts saying " i know a bloke down the pub and he said" type comments.
The people that work on bmw engines and those who actually run a BMW 4.4 V8 on lpg are all very happy Wink .
Post #223924 19th Nov 2013 2:20pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
i drove past a breakers in Chorley lancs yesterday
theyve got a load of 4.4 X5`s parked up
not sure of the name but im sure you can google it Growing old is compulsory Growing up is optional
Post #223935 19th Nov 2013 3:05pm
paneldamage
That will be Douglas Valley Breakers? Never used them but they were showing breaking an L322 on EBay a while back....
Post #223988 19th Nov 2013 9:04pm
johnboyairey
if you take your head(s) off you will need to borrow, or buy a timing setup kit to retime the cams/chains. (£350) if you are dismantling, have you run the bearings? sump off first, cap off etc. might be a better idea to start by hiring a decent lit borescope to look into a bore, with piston down. -maybe a do a compression test first and look at the worst one. did it seize? can it run? these engines are fantastic, but suffer from a few other probs, ie timing guides, vanos rattles, and water system leaks. if you are buying one, ask someone who has one to listen to it. they purr lovely, but some clatter. ive not had one out. I would do lots of other work before even looking at replacing it. and replace those guides and chain. whilst at it. but that's £500 already. hope you have a garage and heater. you will be busy for the winter!
I did the vanos seals when I did my guides/chain. it worked well. don't quote me here, but the block is the unique thing, (edit, the block is same, the sump and oil pump/pump chain are the difference x5 engine is suitable too) on the RR but bmw 7 series vanos engines, m62tub44 are similarpriciple, but different block. (2 wheel RWD), so a warped head 'could' be suitable from this model to replace the RR check the web.
this guide will show you the vanos repair. everything you might do, without taking off the heads. save the file to pc.
http://beisansystems.com/procedures/m62tu_vanos_procedure.htm
Post #223997 19th Nov 2013 10:03pm
RugbyXV
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Baltic Blue
I have one that needs an effective rebuild but the heads etc are excellent, your for £375 collected... Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money!
Post #224005 19th Nov 2013 10:27pm
