Home > In Car Electronics (L322) > Sat/nav questions |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I am guessing here but I think you have a touch screen model , am I right ?
19th Nov 2013 7:55am |
ryanr24 Member Since: 19 Nov 2013 Location: el cajon Posts: 5 |
Yes I do have the touch screen exactly and thanks for the insight |
19th Nov 2013 8:40am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Hi -
19th Nov 2013 9:53am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Tug, the disk will not turn on or off Nav on the move my friend... It should be off from factory and I guess yours will have been turned on sometime in the past and replacing the disc has made your rom reboot/update hence loosing the facility... |
19th Nov 2013 10:08am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
Paul, if you have 'nav on the move' enabled then using the 2011 disc wont affect it, that's what i found with mine anyway...
19th Nov 2013 10:09am |
Only on certain firmware models Stan... |
19th Nov 2013 10:15am |
Ah ! - like I said to ryanr24 - somebody more knowledgeable would be along shortly - thanks fellas !
19th Nov 2013 10:18am |
i'm not sure if there might be some info re the year of the disc in the hidden 753 menu..
19th Nov 2013 10:23am |
Im sure you can bring up a firmware/software code in a secret menu... I'm sure it will be in the wiki |
