![]() | Home > Technical (L322) > Front suspension leak. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
AFAIK the only air pipe on that side is the one that goes to the air bag.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
If its the air line it could be repaired with a couple of connectors and a piece of pipe.
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
Thanks
Today i removed inner wing and hey presto the air pipe had been touching the fbh . Last week i did a system check and ran the fbh for a couple of minutes,resulting in a melted pin prick in the air line. Its in such an awkward place that fitting a compression joint is a no no,so its going to be a case of cobble an air tight seal.
You can get push fit fittings for the airlines, which simply press on. So as long as you can cut it and get your hands to it you should be able to effect a repair.
`Thanks for that have just ordered a couple of connectors. |
Just be careful when you do it, make sure you have the weight of the car on axle stands all round before you cut the pipe |
Good plan Joe! There is nothing that can't be fixed with a hammer😜😜
In fact, disconnect the battery before you start and wait a while, and make sure you have a way of disabling/reenabling the air suspension when you are done, otherwise you are likely to be down in the dumps with no lights on the dash and a bong! .
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
... and after fitting start engine only with closed doors, otherwise no freshair in the airbags, at my first time I wait with running engine 20 minutes.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Thanks guys for your imput.and a big thanks to Northern MonkeyJ For giving me the headsup on the push fittings. They arrived this morning and was such an easy fix. All is good alas if only my battery drain could be resolved as easily.
