Home > Technical (L322) > Front suspension leak.
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Hello all
2 Years ago my front drivers side air bag sprang a leak,it was simple to diagnose as it was loudly hissing from wheel arch. So trip to an indie and job done.
Yesterday i noticed my range seemed to be struggling with front height adjustment. on examination i can hear a calm hissing coming from under the battery tray, passenger side. So my question is that although it does not seem to be coming from the strut, is there air pipes running under the battery,or is it just making me look more stupid then i actually am.!!
Even when i lift suspension to off rd height ,i cant hear it coming from the air bag,so do i just bite the bullet and order a new one from Dan.
Any advice much appreciated.
Cheers Piers
Post #224011 19th Nov 2013 11:09pm
AFAIK the only air pipe on that side is the one that goes to the air bag.
To get at the pipe you will need to drop the inner wheel arch and follow the pipe back from the airbag. Could have developed a split somewhere?
Just in case it is the airbag:
Does it still hiss at access height?
Also try the soapy water test at off road height. .
Post #224030 20th Nov 2013 2:18am
If its the air line it could be repaired with a couple of connectors and a piece of pipe.
Much cheaper than a new strut. There is nothing that can't be fixed with a hammer😜😜
Post #224038 20th Nov 2013 8:31am
piersie
Thanks
whatever the height it only hisses,and can be heard from behind the vent on the front wing. I have read the wiki on strut removal which doesnt look that daunting.
I will remove plastic wing lining and go from there. Fingers crossed. Thumbs Up
Cheers Piers
Post #224085 20th Nov 2013 12:04pm
piersie
Today i removed inner wing and hey presto the air pipe had been touching the fbh . Last week i did a system check and ran the fbh for a couple of minutes,resulting in a melted pin prick in the air line. Its in such an awkward place that fitting a compression joint is a no no,so its going to be a case of cobble an air tight seal.
Still its cheaper then an air bag. Thumbs Up
Post #224351 21st Nov 2013 7:47pm
You can get push fit fittings for the airlines, which simply press on. So as long as you can cut it and get your hands to it you should be able to effect a repair.
Have a search around i seem to remember someone repairing a split line on here somewhere.
Edit.... This is the onehttp://www.fullfatrr.com/forum/topic15626.html There is nothing that can't be fixed with a hammer😜😜
Post #224353 21st Nov 2013 7:55pm
piersie
`Thanks for that have just ordered a couple of connectors. Thumbs Up Thumbs Up
Cheers Piers
Post #224412 21st Nov 2013 10:59pm
Just be careful when you do it, make sure you have the weight of the car on axle stands all round before you cut the pipe Thumbs Up .
Post #224428 22nd Nov 2013 12:19am
Good plan Joe! There is nothing that can't be fixed with a hammer😜😜
Post #224458 22nd Nov 2013 8:39am
In fact, disconnect the battery before you start and wait a while, and make sure you have a way of disabling/reenabling the air suspension when you are done, otherwise you are likely to be down in the dumps with no lights on the dash and a bong! .
Post #224595 22nd Nov 2013 4:50pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
... and after fitting start engine only with closed doors, otherwise no freshair in the airbags, at my first time I wait with running engine 20 minutes.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #224620 22nd Nov 2013 6:48pm
piersie
Thanks guys for your imput.and a big thanks to Northern MonkeyJ For giving me the headsup on the push fittings. They arrived this morning and was such an easy fix. All is good alas if only my battery drain could be resolved as easily.
I must be a real glutton for punishment as i am now considering upgrading to a 2008. If you are ever walking through Henley and you see a guy with Censored tattooed on his forehead pls stop and say hello to me. Thumbs Up
Cheers Piers
Post #225130 25th Nov 2013 3:22pm
