Home > Technical (L322) > Turbos failed and need replacing, help |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
21st Nov 2013 12:06am |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
Re-man turbos £650 ish each + labour & oil feed pipes + oil & filter as well as lift body off which is no biggy. I would charge about £2500 inc vat. i am not quoting for the work but having just done one for someone am able to tell you roughly what you should be paying. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
21st Nov 2013 12:13am |
P1ca Member Since: 20 Nov 2013 Location: London Posts: 5 |
Have to admit the receptionist is wprth the extra rip off,, she's fit lool
Well Hope that gives you an idea of what you should be paying, people try to make out its very labour intensive as you have to remove the body but its very straight forward & takes about 8hrs to remove & refit + access to turbos is then very straight forward so about 12hrs all togethether max 16 with a few headaches to sort. As I am also the receptionist as claire only works parts time I could cut my coveralls of short Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
21st Nov 2013 12:27am |
Is it true they stopped offering the TDV8 on the RRS because the turbo's kept going? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
You would be better asking the question on the RRS forum as they will have far more experience on your model |
21st Nov 2013 12:28am |
I was about to say whats a RRS doing on here but hey if you own a landrover I guess were all glutons for punishment Craig Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
21st Nov 2013 12:31am |
Sorry about going off topic but have you read my question regards poly bushing Craig Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
21st Nov 2013 12:32am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
P1Ca
21st Nov 2013 12:35am |
Nah this is berkshire land rover which in my opinion are ripping me off, but i have no other alternative so have no choice but go with them. They wanted to buy my car the way it is for £22.300, but they selling a 3.0tdv6 for nearly 34k lol . They seem like a joke to me personally but cant do much. They did say they putting recon turbos from land rover, but as long as i get 12 month parts n labour waranty am
21st Nov 2013 9:12am |
Ive not had a PM from you pal... |
21st Nov 2013 9:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
P1ca, you'd be better asking here, http://www.rrsport.co.uk/forum/ ... - .- -.
21st Nov 2013 9:45am |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Body off to do the turbos...... FFS.... |
21st Nov 2013 9:50am |
I would get a few quotes before going with them.
21st Nov 2013 11:41am |
