Home > Technical (L322) > 08MY clock and radio presets resetting
Martin
Site Admin
Hi all,
Anyone know why the digital time resets to 00:00 and the radio presets are lost when leaving the FFRR locked up overnight (or even for a few hours) Confused ?
Post #22354 14th Jul 2010 9:25pm
I reckon its something to do with the memory settings, sometimes I find my steering wheel settings keep changing back. I've never had radio stations lost but I have had the clock go hours off once for no good reason.
Like most things in the L322, they seem to happen for a while then it just works normally. There never seems to be a good reason. Discovery 4 HSE
Post #22356 14th Jul 2010 9:37pm
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
just another characteristic Whistle No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #22360 14th Jul 2010 10:02pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Never had that clock issue, but I've had some with the nav system.
Sometimes, it resets itself, loosing the country (resetting itself to Belgium....go figure.... Laughing Laughing ), last destinations, etc....
It's not another car ''characteristic'', it is CHARACTER...... Laughing Laughing Laughing Laughing
Post #22385 15th Jul 2010 10:49am
Martin
Site Admin
Only started doing it recently though Confused
Post #22391 15th Jul 2010 11:58am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Sounds like possibly a sleep mode problem. The car goes into sleep mode after a period of time to save battery power. Maybe something to do with that. I'd try a hard reset to clear any faults and see if it cures it?
Post #22422 15th Jul 2010 6:31pm
Martin, it's a LAND ROVER. Come on.... Discovery 4 HSE
Post #22426 15th Jul 2010 7:37pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I'm starting to have the same problem.
Funy thing is the analogue clock seem to maintain the time, it's the NAV clock that resets, and the only way I realise that is when the nav calculates my arrival time at 00:40 for a 40 minute journey starting at 09:00!
I thought it might have something to do with using the "spare" key.
Post #131815 18th Jul 2012 3:03pm
Battery problems maybe as we all know that when the battery starts to go EOL the issues that come up can be strange and wonderful??
Try having a trickle charger on the car overnight maybe and see if it helps(if you have one).
Does the time reset before or after the engine is cranked? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #131818 18th Jul 2012 3:13pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
+1 for battery/power supply. its got to be powered from somewhere on a constant feed to maintain clock and radio presets
not sure if there is a separate fuse for that might be worth looking.
Is it every time you park it up? Mine was a blue one! Smile
Post #131821 18th Jul 2012 3:18pm
Andy3681
Sorry Martin re read your post it is every time so that looks like a power supply issue Mine was a blue one! Smile
Post #131822 18th Jul 2012 3:20pm
mine did this a few times, seems it may have been either a battery issue or something to do with being opened with the spare key, not the usual one i use.
However if you are not doing this then its probably the Battery i should coco. There is nothing that can't be fixed with a hammer😜😜
Post #131853 18th Jul 2012 5:20pm
millerj90
Lost the radio stations and the digital (Nav) clock reset to 00:00 again today.
The car was started with the "spare" key and taken for a motorway run for some 45 minutes, so I'm not suspecting (but could be wrong) the main battery.
I switched off and locked the car (still with the spare key) whilst I fuelled up, on returning to the car I used my normal key to unlock and start .... boom, radio channels gone.
Whilst its not a major problem as I use the same key all the time, it is a little annoying, and I'm sure it shouldn't do it.
Any ideas?
Post #135406 10th Aug 2012 8:28pm
Its ow i know the missus had been in the car. Resets on mine when we use the spare key.
Try running it with the spare for a while and setting everything to how you like it.
Then womt notice when it swaps to the other keys settings.
Its an idea anyhow....... There is nothing that can't be fixed with a hammer😜😜
Post #135421 10th Aug 2012 9:46pm
