![]() | Home > Technical (L322) > creaking suspension |
Most likely a bottom balljoint on its way out. You should get it investigated sooner rather than later |
You'll get a clunk from the front rather than a creak I would have thought.
Creaking balljoints are common and once they start its best to have them changed as soon as possible. I had one on my TD6 that was just starting to creak when I replaced it |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
yep its your front lower balljoint, just done mine to get rid of the creak. 2004 black Vogue TD6 |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
thanks for the response is it a easy job doing the ball joints |
Technically easy but can be a PITA getting the balljoint off, your need a ball joint splitter and be carefull you do not damage the boot above.
specman Member Since: 20 May 2010 Location: Fife Posts: 250 ![]() ![]() ![]() |
If you are getting the noises do the lower ball joints as mentioned.
This noise is not a clunk its like an old door closing and the strange thing is it only happens when i turn the steering wheel tto the right it does not make a noise when i turn to the left on listening it also appears to be comming from higher up than the ball joints
If its creaks when stationary then get someone to wiggle the wheel while you hold each suspension arm, you should feel the vibration at the same time as the creak. Failing that you might need to get it on a ramp mate..Good Luck.. 2004 black Vogue TD6 |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Does seem strange.
Hi Guys
Its was balljoint but you orderd track Rod ends? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
holy thread revival batman. |
Thats the beauty of search Stan rather than a new thread.... |
