Home > Technical (L322) > creaking suspension
oodathort
creaking suspension
Hi all
Can anyone shed any light on my problem with my TD6 if i turn steering to left no probs no noise however as soon as i get past straight ahead and continue to turn to the right i get a noise simmilar to a old creaking door sort of noise and doesent eminate from the steering pump its around the suspension leg / control arms i have sprayed all rubbers with wd40 and also luricated the bearing on top of the leg but to no avail ???
Post #34648 2nd Nov 2010 8:51pm
Most likely a bottom balljoint on its way out. You should get it investigated sooner rather than later
Post #34649 2nd Nov 2010 9:01pm
dan_uk_1984
You'll get a clunk from the front rather than a creak I would have thought.
I had a creaking on the rear suspension that turned out to be a rubber bush. Can you say for sure it's at the front?
Post #34653 2nd Nov 2010 9:26pm
Creaking balljoints are common and once they start its best to have them changed as soon as possible. I had one on my TD6 that was just starting to creak when I replaced it
Post #34654 2nd Nov 2010 9:37pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
yep its your front lower balljoint, just done mine to get rid of the creak. 2004 black Vogue TD6
Post #34669 2nd Nov 2010 10:55pm
oodathort
thanks for the response is it a easy job doing the ball joints
Post #34747 3rd Nov 2010 9:00pm
letsavit2
Technically easy but can be a PITA getting the balljoint off, your need a ball joint splitter and be carefull you do not damage the boot above.
if you get someone else to do it the job shouldn't cost anymore than £100 including parts, whole new arm with balljoint = £50 and hours labour tops, any garage can do it not a specialist job. Might also be worth considering doing the other side if not done already, it will possibly go soon aswell. 2004 black Vogue TD6
Post #34753 3rd Nov 2010 10:01pm
specman
Scotland 2016 Range Rover Vogue SE SDV8 Aruba
If you are getting the noises do the lower ball joints as mentioned.
Be worthwhile doing the track rod ends too.
My TDV8 was making clunky noises and my local Indie LR specialist Mike Aitken had a look and would not let me away without doing the track rod ends, it didnt fully stop the clunking so a few days later he did the lower arms too.
Now it is nice and tight.
My pal's D3 had new balljoints and 40k too, my 7 series were the same so it really just comes with the beefy cars TBH.
Post #34771 3rd Nov 2010 11:09pm
oodathort
This noise is not a clunk its like an old door closing and the strange thing is it only happens when i turn the steering wheel tto the right it does not make a noise when i turn to the left on listening it also appears to be comming from higher up than the ball joints
Its a toughie
Post #34785 4th Nov 2010 7:43am
letsavit2
If its creaks when stationary then get someone to wiggle the wheel while you hold each suspension arm, you should feel the vibration at the same time as the creak. Failing that you might need to get it on a ramp mate..Good Luck.. 2004 black Vogue TD6
Post #34892 4th Nov 2010 8:46pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Does seem strange.
As suggested might be a good idea to get it on a ramp
Post #34902 4th Nov 2010 9:28pm
oodathort
Hi Guys
I must congratulate you all your diagnosis was spot on bottom ball joint it is what i did was pierce the rubber with a small screwdriver pour some oil along the screwdriver hey presto noise gone will order new and trackrods for both sides
Regards
Stuart Thumbs Up
Post #34948 5th Nov 2010 10:06am
Its was balljoint but you orderd track Rod ends?
Post #224354 21st Nov 2013 7:58pm
holy thread revival batman. Shocked
3 years is a long time.. ... - .- -.
Post #224355 21st Nov 2013 8:00pm
Thats the beauty of search Stan rather than a new thread.... Whistle
Post #224356 21st Nov 2013 8:01pm
