Home > Technical (L322) > How far can I expect the dealer to go.
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Some time ago my 2 year old VSE developed a low volume noise which can best be described by me as if someone is blowing gently on on open pipe end or across the end of a bottle. The noise isn't loud and although the noise is constantly there at between 25 and 45 mph it is no a constant noise if that makes sense. It went in for service 2 months ago and to have this fault looked at and although they could hear the noise they could not find out the cause and asked that I let it develop further in order to diagnose it. Now it hasn't got much worse but the fact that I am tuned in to the noise makes it a continual source of annoyance when driving as I am listening for it all the time. I have spoken to the dealer and booked in again for next week to see if it can be sorted but my question is how far can I expect them to go with this and how much time can I reasonably expect them to spend on the problem. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #224531 22nd Nov 2013 2:03pm
if the dealer cant find the cause then you're stumped really....if it was an obvious fault then there would be no problem fixing it..
have you checked that the windows and sunroof are fully closed?...i'm thinking maybe wind noise.. ... - .- -.
Post #224589 22nd Nov 2013 4:40pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Have to ask ... does it appear at a certain rev range? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #224591 22nd Nov 2013 4:45pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Check the turbo pipework for splits it might be a boost noise
Post #224594 22nd Nov 2013 4:50pm
duckworthparts
Site Sponsor
make sure you go on a road test with the tech so you can point out the noise You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #224596 22nd Nov 2013 5:01pm
Pfazz
Wind noise of some sort is my gut feeling but I've checked all windows and sunroof, it doesn't come and go at a certain rev range it appears around 20 mph but is at its loudest around 35/40 mph although it is never very loud, i don't think it actually goes away at higher speeds it's just the extra bit of road noise drowns it out somewhat. It could well be something as simple as wind whistling past something under the car such as deployable side steps for example, difficult one really. Agueroooooooooo. 93-20
Post #224598 22nd Nov 2013 5:06pm
duckworthparts
Site Sponsor
front outer A pillars secure ? You can paypal direct using - www.paypal.me/duckworthparts
Post #224600 22nd Nov 2013 5:16pm
Windscreen scuttle needs pushing down to clip in....
Post #224601 22nd Nov 2013 5:18pm
Perce
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Re: How far can I expect the dealer to go.
Pfazz, I would be very interested to hear if you get this sorted, as I have the same model and exactly the same issue. At first I thought it was road noise, but it continued on different surfaces. I drove along thinking 'how do I describe this noise to the service department when I take it in'? .. But you've nailed it, It's exactly like someone gently blowing across a bottle top. It's in the background, but noticeable.
Post #224616 22nd Nov 2013 6:29pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Now don't quote me for exact location here but my mate had his 2012 Westminster repaired earlier this year and there was what I can best descibe as a foam blanking cover that went somewhere in the region of where the A pillar meets the inner wing. It hadn't been fitted as the new one hadn't arrived and it produced a similar wind noise to what you have described. Once the new one was in it was all good.
Sorry for the vague discription. I'll see if he can shed anymore light on it.
Post #224624 22nd Nov 2013 6:59pm
Pfazz
Thanks for the ideas I will have scout round and see if I find anything bearing the above ideas in mind. Keep the information coming though because I think if I can't find I will finish up changing the car sooner rather than later it is so annoying. Agueroooooooooo. 93-20
Post #224631 22nd Nov 2013 7:23pm
Pfazz
Perce have you got deployable side steps fitted? Agueroooooooooo. 93-20
Post #224634 22nd Nov 2013 7:55pm
Perce
No, mine are fixed. So you can probably cross that one off of your list.
Post #224635 22nd Nov 2013 7:58pm
Googsy
Bring it to another dealer Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #224637 22nd Nov 2013 8:06pm
