![]() | Home > Technical (L322) > Possible Dumb Question 2010 LED DRL'S But Here Goes |
They work when you turn on sidelights. Alternatively if you have iid tool I think some members have been able to enable that function. Present :2008 TDV8 HSE
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
The dealer will do this for you when they hang the fury dice on the rear view mirror. |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
Apparently they don't work as DRL. DRL would be main beam bulb on low voltage |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
L322's can NOT have the LED's initiated on the CCF files im afraid...The only way to have them on as DRL's is to wire them in that fashion... |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
We've been here before Craig, it can be done |
Ahh, my point was it's not something a uk main dealer can do through the CCF files |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Ajay, is a LR specialist likely to do this if LR won't?
Worse case is an auto electrician wiring in a £4 5 pin relay! |
Just need to find someone with fault mate now! |
That is brilliant since I do have a faultmate and I have my software license changed to the 5.0 |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 ![]() ![]() ![]() |
sorry to resurrect - but is this something that a dealer or specialist could do on my MY2012 Westminster? |
Yes, we can sir |
Craig - great |
PM sent |
