|  | Home > Technical (L322) > Possible Dumb Question 2010 LED DRL'S But Here Goes |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947      | They work when you turn on sidelights. Alternatively if you have iid tool I think some members have been able to enable that function. Present :2008 TDV8 HSE
|  21st Nov 2013 12:53pm |
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1125    | The dealer will do this for you when they hang the fury dice on the rear view mirror.   | ||
|  21st Nov 2013 2:56pm |
| GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61      | Apparently they don't work as DRL. DRL would be main beam bulb on low voltage | ||
|  21st Nov 2013 10:25pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | L322's can NOT have the LED's initiated on the CCF files im afraid...The only way to have them on as DRL's is to wire them in that fashion...  | ||
|  21st Nov 2013 10:35pm |
| Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608      | We've been here before Craig, it can be done  | ||
|  22nd Nov 2013 10:18am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Ahh, my point was it's not something a uk main dealer can do through the CCF files  | ||
|  22nd Nov 2013 11:40am |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717      | Ajay, is a LR specialist likely to do this if LR won't?
|  22nd Nov 2013 7:59pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Worse case is an auto electrician wiring in a £4 5 pin relay! | ||
|  22nd Nov 2013 8:09pm |
 Just need to find someone with fault mate now! | ||
|  26th Nov 2013 9:35pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | That is brilliant since I do have a faultmate and I have my software license changed to the 5.0  | ||
|  20th Oct 2014 2:50pm |
| tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55      | sorry to resurrect - but is this something that a dealer or specialist could do on my MY2012 Westminster? | ||
|  30th Apr 2016 6:25am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Yes, we can sir  | ||
|  30th Apr 2016 9:17am |
| tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55      | Craig - great  | ||
|  30th Apr 2016 10:31am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | PM sent  | ||
|  30th Apr 2016 10:20pm |
| Posting Rules
 My own 2010MY FFRR 3.6 TDV8 has just the front signature lights enabled as DRL's using my Faultmate MSV-2
