![]() | Home > Technical (L322) > Lumbar support |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
Hi guys had a play about with the electric seats and noticed the lumbar support isn't working? Any ideas does it maybe run off a seperate fuse? Or could it be the motor is just knackered! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
sometimes they get inflated to the max and cant deflate so you have to manually let the air out.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
There are air vacume pipes which fall off the back of the switchgear & air motors for a past time |
Thanks Stan but do you know how to manually deflate the lumbar? F**K IT you only live once |
Thanks Craig any diagrams or steps to follow? F**K IT you only live once |
number 5 in diagram, but Craig is much more knowledgeable so i'd go with his recommendation..
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
I have the same problem! |
