Home > Technical (L322) > Lumbar support
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Lumbar support
Hi guys had a play about with the electric seats and noticed the lumbar support isn't working? Any ideas does it maybe run off a seperate fuse? Or could it be the motor is just knackered! Sad Big Cry F**K IT you only live once
Post #225254 25th Nov 2013 11:09pm
sometimes they get inflated to the max and cant deflate so you have to manually let the air out.. ... - .- -.
Post #225285 26th Nov 2013 9:15am
There are air vacume pipes which fall off the back of the switchgear & air motors for a past time Thumbs Up
Post #225289 26th Nov 2013 9:29am
stuboy00
Thanks Stan but do you know how to manually deflate the lumbar? F**K IT you only live once
Post #225290 26th Nov 2013 9:31am
stuboy00
Thanks Craig any diagrams or steps to follow? F**K IT you only live once
Post #225292 26th Nov 2013 9:40am
number 5 in diagram, but Craig is much more knowledgeable so i'd go with his recommendation..
Post #225294 26th Nov 2013 9:44am
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
I have the same problem! Sad
Is easy to do it? Or need to be done by an expert?
thanks, Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #225317 26th Nov 2013 11:46am
