![]() | Home > Technical (L322) > Can I Charge Phone Via USB Port 2010 MY |
Have you tried it? .
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
mmmm plug it in and see.... |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
If id done that I would know the answer. I haven't got the lead and didn't see much point buying one if it doesn't work anyway hence the question |
Then why not just buy the 12v charger lead? |
Carlos, the USB in the car has the same capabilities for charging as your USB on your PC. So, if it works to charge it on a PC it will work in the car ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35822 ![]() ![]() |
you can buy one of these for less than a fiver off ebay if your ranges usb doesnt work..
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Well, it doesnt charge an iphone.... Discovery 4 HSE
It charged mine - however you need to make sure you have the correct cable, the early ones didn't have the charging ability (I had to buy an adapter....) Land Rover Addict
To be honest the USB spec allows for upto 500ma on most systems and setups so will charge some phones but be very very slow.
DMRR, do you mean early 2010 MY? Mine is a 2009 59 plate so would fall into that category if you do?
Sorry, Im saying anything you charge for a solo USB port that is built to spec or near to spec will charge at a much slower rate than a good USB Accessory socket charger.
