|  | Home > Technical (L322) > Can I Charge Phone Via USB Port 2010 MY |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Have you tried it? .
|  29th Nov 2013 12:27am |
| XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995      |
|  29th Nov 2013 7:53am |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | mmmm plug it in and see.... | ||
|  29th Nov 2013 8:03am |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717      | If id done that I would know the answer. I haven't got the lead and didn't see much point buying one if it doesn't work anyway hence the question | ||
|  29th Nov 2013 8:09am |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | Then why not just buy the 12v charger lead? | ||
|  29th Nov 2013 8:12am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      |
 Carlos, the USB in the car has the same capabilities for charging as your USB on your PC. So, if it works to charge it on a PC it will work in the car   | ||
|  29th Nov 2013 8:28am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | you can buy one of these for less than a fiver off ebay if your ranges usb doesnt work..
|  29th Nov 2013 8:29am |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | Well, it doesnt charge an iphone.... Discovery 4 HSE
|  29th Nov 2013 8:47am |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027      | It charged mine - however you need to make sure you have the correct cable, the early ones didn't have the charging ability (I had to buy an adapter....) Land Rover Addict
|  29th Nov 2013 9:09am |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | To be honest the USB spec allows for upto 500ma on most systems and setups so will charge some phones but be very very slow.
|  29th Nov 2013 2:34pm |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717      | DMRR, do you mean early 2010 MY? Mine is a 2009 59 plate so would fall into that category if you do?
|  29th Nov 2013 2:42pm |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | Sorry, Im saying anything you charge for a solo USB port that is built to spec or near to spec will charge at a much slower rate than a good USB Accessory socket charger.
|  29th Nov 2013 3:07pm |
| Posting Rules
