![]() | Home > Technical (L322) > Coolant escaping from coolant cap |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
it could be the right time to change the thermostat, should a correct cap not sort it. fairy liquid suds on paintbrush is a quick leak detector, to save you burning your earhole -should it vent in anger!
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
if the radiator is getting hot and the engine temp is not rising above 105 degrees would this not indicated the thermostat is working correctly?
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
I'm no expert but i seem to recall hearing that a HGF under rare circumstances may exhibit signs of allowing combustion gasses into the coolant (but not oil) thereby raising the pressure in the system.
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
Katash, you are correct HGF can happen between cylinders and water galleries, cylinders and oil galleries, oil galleries and water galleries or all 3.
i am thinking of getting one of these kits to just try and rule out any gases in the coolant, has anyone ever used one on the M62 engine before?
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Matt. I wouldn't get a kit. I had a test done soon after I got mine. The result from the garage was not good, but had no signs go HGF. 3years later and still no issues. Apparently the chemical fluid can degrade over time??? I would get a proper test with a propper gas monitor. Might be something to do with the coolant being glycol based? Just my 2p worth. I would put the right cap on first then see what happens. You may find once 200 cap fitted you get other water leaks due to the increase in pressure and age of coolant system. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I'm ordering the 200 rated cap from BMW tomorrow as land rover don't supply it. I have replaced the majority of the cooling system over the last 3 years.
I wouldn't lose sleep yet. The facts are the car runs well and is showing no physical signs of HGF. You do have an underrated pressure cap on your tank which is leaking. Work with the facts and not what ifs. I never got the HGF thing out of my mind and took a lot of joy out of the car. Dont go down the same road I did. |
have fitted the 200 rated cap, will see how it goes
just to follow up, I do have the 140 cap I checked top and underneath yesterday. mines ok. (2002 v |
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53
So did the 200 cap work? I am haveing simulate problems and mine has a 140 cap from landrover.
yes so far so good, no over pressurising no leaks |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
good job Matt |
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
Hi Matt, still no worries since you fitted he 200 cap? what year is/was you 4.4L V8 please? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
| All times are GMT |
