Home > Technical (L322) > Coolant escaping from coolant cap
Page 2 of 3 <123>
Bizzarely lists the same part numbers for both the 3.0 td6 and the 4.4 v8, go figure......
edit I stand corrected, the Higher pressure cap is listed for Vin unto 1A001049 the part number is, PCD100200L for the 200 marked cap. There is nothing that can't be fixed with a hammer😜😜
Post #226352 1st Dec 2013 3:30pm
johnboyairey
it could be the right time to change the thermostat, should a correct cap not sort it. fairy liquid suds on paintbrush is a quick leak detector, to save you burning your earhole -should it vent in anger!
i have same v8 i will have look at my number when she gets home, and its cooled down. ie tomorrow.
Post #226365 1st Dec 2013 5:35pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
if the radiator is getting hot and the engine temp is not rising above 105 degrees would this not indicated the thermostat is working correctly?
Matt
Post #226378 1st Dec 2013 6:28pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I'm no expert but i seem to recall hearing that a HGF under rare circumstances may exhibit signs of allowing combustion gasses into the coolant (but not oil) thereby raising the pressure in the system.
I also recall seeing a testing kit that you fit to the expansion tank that will detect said gasses.
Otherwise maybe a failing water pump.
Post #226393 1st Dec 2013 7:10pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Katash, you are correct HGF can happen between cylinders and water galleries, cylinders and oil galleries, oil galleries and water galleries or all 3.
The kit you are referring to is a block test kit 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #226413 1st Dec 2013 8:38pm
mattstevenson2005
i am thinking of getting one of these kits to just try and rule out any gases in the coolant, has anyone ever used one on the M62 engine before?
Matt
Post #226436 1st Dec 2013 10:21pm
Matt. I wouldn't get a kit. I had a test done soon after I got mine. The result from the garage was not good, but had no signs go HGF. 3years later and still no issues. Apparently the chemical fluid can degrade over time??? I would get a proper test with a propper gas monitor. Might be something to do with the coolant being glycol based? Just my 2p worth. I would put the right cap on first then see what happens. You may find once 200 cap fitted you get other water leaks due to the increase in pressure and age of coolant system. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #226442 1st Dec 2013 10:48pm
mattstevenson2005
I'm ordering the 200 rated cap from BMW tomorrow as land rover don't supply it. I have replaced the majority of the cooling system over the last 3 years.
New water pump before I purchased the car
New radiator.
New top hose assembly
New temp sensors
New coolant tank
New coolant cap
New rear engine coolant pipes
New transmission cooler thermastat
I'm going to give the higher rated cap a go, but just hoping nothing else gives way because of the increase in pressure. To be honest I'm really worried about it as this issue has come from no where really. No signs of the car getting too hot or over pressuring of the coolant system, so totally out of the blue. Car drives perfectly absolute no loss of power or performance, no error messages or warnings sorted I'm the ECU.
Matt
Post #226450 2nd Dec 2013 12:00am
I wouldn't lose sleep yet. The facts are the car runs well and is showing no physical signs of HGF. You do have an underrated pressure cap on your tank which is leaking. Work with the facts and not what ifs. I never got the HGF thing out of my mind and took a lot of joy out of the car. Dont go down the same road I did. Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #226486 2nd Dec 2013 11:34am
mattstevenson2005
have fitted the 200 rated cap, will see how it goes
Matt
Post #226576 2nd Dec 2013 8:42pm
johnboyairey
just to follow up, I do have the 140 cap I checked top and underneath yesterday. mines ok. (2002 vCool
on the head gasket check, talk to an indy, they have a fluid detecting kit. you basically draw the air inside tank out that has come from coolant evaporation. and observe the colour change. its expensive stuff. snap on do a kit. it only takes 10 mins. there was an episode of wheeler dealers a long time back where he did a check.
here is a typical test. only wish he'd used a petrol engine those disco boys, love a diesel!
this should not be a definitive test but an indication of what to think about doing next....
head gaskets are a huge job. toolset required. and hours of time!
Post #226648 3rd Dec 2013 10:19am
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
So did the 200 cap work? I am haveing simulate problems and mine has a 140 cap from landrover.
Mick
Post #227553 7th Dec 2013 5:47pm
mattstevenson2005
yes so far so good, no over pressurising no leaks Very Happy
Matt
Post #227684 8th Dec 2013 8:57pm
good job Matt Thumbs Up ... - .- -.
Post #227776 9th Dec 2013 11:34am
verydisco
Hi Matt, still no worries since you fitted he 200 cap? what year is/was you 4.4L V8 please? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #317612 12th Mar 2015 1:01am
Page 2 of 3 <123>
