![]() | Home > Technical (L322) > TDV8 Cam(belt) or (chain) |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1845 ![]() ![]() |
TDV8 is chain driven, with an aux polybelt |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
The TDV6 engine was belt driven that was fitted to the sports & discovery, the TDV8 is indeed a chain:D Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
er...that sounds like a belt? |
An aux belt is a belt, that drives the P/S pump, alternator etc.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I thought so....I don't know, those boys and their "sports"....pfft |
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
When does the chain need changing? Is it 100k? Anyone recommend getting this done a bit early? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Should never need changing unless there is an issue |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
with Land Rover are You joking ![]() |
Read the first reply to that and thought, Great!! Then read below that and thought, Hmmm?
Yes, everyone i know with a TDV8... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Ever changed one Craig?
