![]() | Home > Technical (L322) > Questions about my new L322 4.4 FFRR! |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 105 ![]() ![]() ![]() |
Please share any experience you have with doing things yourselves on the L322! Deeply Appreciated! |
rjp996 Member Since: 28 Apr 2009 Location: East Sussex Posts: 22 ![]() ![]() ![]() |
In most cases, a cars a car when working on the mechanics. I've done bits on my cars from a fiat punto through to a Ferrari. When you get down to it, they all work much the same way, just don't be intimidated by their cost. The RR I have found is good as its big and bits are relatively easy to get to. Downside is the weight always feels a lot hanging over you when under it, but a 1 tonn or a 3 tonn car on your chest really makes little difference. Lots of specialist LR parts places out there, I've found parts to be not badly priced at all. Breaks and discs all around are not expensive and only take 1hr to fit (I'm not quick either). PLUS - there is a Lot of excellent knowledge on this forum and around the web for almost every part of the car (unlike trying to find how to extract a gearbox ecu from a W169 Merc....). |
If you're doing DIY you really need a diagnostics tool which is one reason I've done very little myself. I should really get one.
Hi Marius,
Yes you should. ![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
993 C4S, now there's a CAR!! |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
All depends on the level of your DIY.
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
I've had mine for 9 months and it is a 2003 4.4 V8 with 147k on the clock, its just great and I cant imagine ever being without a FFRR. So far anything that has gone wrong I have been able to fix (this forum is so useful for help and advice), most things have been fairly minor and it sailed through its last MOT. I took the advice from here and bought one that appeared to have been well maintained and mileage was secondary. Parts are very easy to get and seem to be reasonable. I'd go for it - just take your time and find a good one and have a good root about on here for advice on what to look for when buying - loads of really helpful stuff. |
Hi again,
Lots of threads on diagnostics.
Done loads on mine, all reasonably straight forward and plenty room to get in around things. Definitely need diagnostic tools for the electronics but these are not expensive and the knowledge on the forum is great |
My Jag-mechanic has a Oslo Blue 03' L322 Vogue. Low milage.The car is in very good shape, but the engine is shot. He doesn't have the time to fix it (allthough he wants to).
rvank Member Since: 02 Nov 2013 Location: Texas Posts: 42 ![]() ![]() ![]() |
I haven't done too much outside of oil and fluid changes and a few basic repairs, but so far it's proven to be easy enough to work on. I always do repairs myself though on all my cars (and have done so since I was a kid - helping dad that is). Aside from how many extra bits you have to remove to get to something, I find the RR to be just as DIY friendly as any other car (with my wrangler there is nothing in the engine bay except the engine so it's not a problem, but boy are there a ton of gadgets in that RR bay).
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
These cars are not that frighteneing to work on as long as you have as a bit of knowledge and sympathy. After all they are just bits of metsal and plastic held together with nuts and bolts controlled by complex electroncs. Nearly all information is available on this site and others for working on these cars, except for some reason why I have my my OBC display which no sitre has been able top answer |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
An engine @ £4K if you can find one |
