Home > Technical (L322) > Front driveshafts
paneldamage
Front driveshafts
Hi All, I have an annoying vibration at around 30-33 mile an hour, think it's a front driveshaft on the offside, out of balance or CV worn, on my 2007 S/C. Can any body confirm if the driveshafts are all the same throughout the model years? There are a few on the bay at the moment off TDV8's, I would hazard a guess that they are the same up to 2010???
Alternatively, has anybody tried having the shaft balanced? I had a firm make some driveshafts years ago, they also made and balanced propshafts...
Thanks in advance, Les
Post #227735 9th Dec 2013 12:00am
adigorn
never changed a half shaft due to vibration
are you triple positive ???
Post #227736 9th Dec 2013 12:05am
paneldamage
Not triple positive Adam, thought it was the box, but it does it in or out of gear at different rpm, the only constant being the speed, had the wheels balanced, changed a rumbly bearing, checked the diffs seem fine.
Mine had a bump on the drivers side front corner, damaged the bottom arm / ball joint, o I am wondering if this has somehow unbalanced the shaft
What's your thoughts?
Post #227740 9th Dec 2013 12:36am
adigorn
hardly dealt with altered ones Mr. Green
but what comes to mind is calipers Question
how it feels is the steering moving left to right?
Post #227741 9th Dec 2013 12:42am
paneldamage
No pulling side to side, stops dead straight, no overheating on the calipers, no drag and no tight spots when spinning the wheels by hand with the car jacked up, had the 4 wheel alignment done
Post #227742 9th Dec 2013 12:51am
adigorn
if its half shafts
that would be inner joints
check the play in them (by hand)
Post #227743 9th Dec 2013 12:59am
Warning!!! There is a special tool for pushing/pulling the driveshafts through the hubs... 8 out of 10 times a DIY mechanic wont remove tem Thumbs Up
We have them made by a local Engineers shop if you need to buy one Thumbs Up
Post #227754 9th Dec 2013 8:38am
paneldamage
Back to my first point - are all the shafts the same?
Post #227926 9th Dec 2013 11:37pm
No... Neutral
Post #227929 10th Dec 2013 12:00am
a016738
United States 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Would love to know what this actually is...I have the very same on my '07 SC but at near exactly 20 mph...from about 19/20 to about 23 mph...more pronounced after it's sat for 30 mins or more...but it's a very light "whomp whomp whomp whomp" type of sound/vibration. Almost sounds/feels like a tire with a broken belt does but again only at this speed. Tire rotation does nothing to change the problem.
Sorta feels like it's from the front left (driver's side here across the pond).
-John
'07 SC
Post #228399 11th Dec 2013 6:55pm
paneldamage
Craig... I assume the shafts are the same after 2006? No different between the TDV8, 4.2, 4.4 ? It's just I can get my hands on a cheap low miles o/s shaft off a TDV8....hoping it fits the 4.2 S/C
Post #228772 13th Dec 2013 12:47am
Certainly the same as a 4.4V8 sir Thumbs Up
Post #228774 13th Dec 2013 1:03am
